Discuss
Oven Error Codes
 in
Gene , yes the wires was remove , also there were 120v at both elements
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #41 (permalink)
Old 07-22-2008, 10:59 AM
w2002s w2002s is offline
Junior Member
w2002s is on a distinguished road
Default
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #42 (permalink)
Old 07-23-2008, 03:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
w2002s,
Check if there is 120VAC between the red wire (R-1 on the wiring diagram) at the control board and ground. If the reading is wrong then one of two 120VAC legs to the oven is missing. It could be the circuit breaker or a broken wire.
__________________
Professional appliance repair in Los Angeles, California.
  #43 (permalink)
Old 07-24-2008, 11:01 AM
Junior Member
Default oven codes
Gene, I check R1 to ground there is 120 v. from BLK 6 to ground at the control 120v . 240v going in.
  #44 (permalink)
Old 07-24-2008, 09:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
w2002s,
There is proper power to everything in the oven, according to your reports. You just replaced the EOC.
The oven is still not working with unknown error code -1- which I never heard for all my life. Double check all electrical connections and components and if there is nothing wrong, call a certified technician.
__________________
  #45 (permalink)
Old 07-27-2008, 04:35 PM
Monk Monk is offline
Junior Member
Monk is on a distinguished road
Default oven errorcodes
my crosley gas range wouldn't come up to temp. I replaced the complete clock/relay and things worked fine. Now working for 3 months and an F1 error code comes on approx once a day and beeps? In the middle of the night when the oven is non operational. Can anyone help?
  #46 (permalink)
Old 07-28-2008, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Monk,
What is the complete model number of the range?
__________________
  #47 (permalink)
Old 07-28-2008, 09:22 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi Monk,
Hi Gene,
Crosley CG3478XRW s/n 14C328109284
Thx,
Monk
  #48 (permalink)
Old 07-30-2008, 04:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Monk,
Most likely the problem is a bad touch pad.
- The part number for the control panel is AP304866
Here are the break down diagrams for the Crosley range Model CG3478XRW
__________________
  #49 (permalink)
Old 07-30-2008, 05:51 PM
after5ive after5ive is offline
Junior Member
after5ive is on a distinguished road
Default
i have a thermodor sc302tb double wall oven with a f2 error code. i called
thermodor and they are no help. do you have any suggestions
  #50 (permalink)
Old 07-30-2008, 06:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "F2" error code means "temperature runaway detected by the control".
For which oven, upper or lower, the error code was shown?
In which mode: time of the day, cooking or self cleaning the error code was shown?
__________________
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
