Discuss
Oven Error Codes
 in
w2002s, What was the original problem? What is the complete model number of the oven? Gene.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #31 (permalink)
Old 07-20-2008, 02:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
w2002s,
__________________
  #32 (permalink)
Old 07-20-2008, 03:05 PM
w2002s w2002s is offline
Junior Member
w2002s is on a distinguished road
Default oven not heating broil or bake
the original problem had an error code -1-.I replaced the EOC, now theres is still no heat. the model # is figidare FEB24S5ABB
  #33 (permalink)
Old 07-20-2008, 03:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by w2002s View Post
... had an error code -1-...
You probably mistyped?
__________________
  #34 (permalink)
Old 07-20-2008, 03:43 PM
Junior Member
the eoc were replaced .but the oven still not heating up. The clock work , buttom works. what do you think the problem is.
  #35 (permalink)
Old 07-20-2008, 11:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What was an error code shown originally on the display?
__________________
  #36 (permalink)
Old 07-21-2008, 10:26 AM
Junior Member
Hi Gene ,the error code on the display was -1- this is no type error
  #37 (permalink)
Old 07-21-2008, 12:49 PM
fishnugget fishnugget is offline
Junior Member
fishnugget is on a distinguished road
Default F2 E6 Whirlpool
I am getting this code on my double oven. RBD276PDB12
What should I do? What parts do I need? How hard is it to do?
  #38 (permalink)
Old 07-21-2008, 01:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
w2002s,
According to the wiring diagram there is a safety thermostat (#141 on the break down diagram) which, if it's open, interrupts power to both heating elements. I'm not sure where it's located. It could be on top of the oven (behind the control panel) or on the back of the oven.
- The part number for the safety thermostat is AP2145826
__________________
  #39 (permalink)
Old 07-21-2008, 04:51 PM
Junior Member
Hi Gene I check the safety thermostat with a digital ohm meter across the two prone it displayed 00.0. do that indicate a closed circuit?
  #40 (permalink)
Old 07-21-2008, 05:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you disconnect wires from the thermostat prior to testing?
__________________
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
