Discuss
Oven Error Codes
 in
Hi SMIMS, In order to provide most accurate advise I need the complete model number of the range. Gene.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #21 (permalink)
Old 03-10-2008, 02:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi SMIMS,
__________________
  #22 (permalink)
Old 04-28-2008, 03:51 PM
Jane DeGroat Jane DeGroat is offline
Junior Member
Jane DeGroat is on a distinguished road
Default
I have a Thermador Model GSC30CVWC used range just hooked it up , oven will not work flashing F3 error code
  #23 (permalink)
Old 04-30-2008, 07:27 AM
aj3 aj3 is offline
Junior Member
aj3 is on a distinguished road
Default GE Profile Double Oven Error Code F7
Oven (GE Profile Double Oven Model #JTP56W0D1WW)had not used for 10 days and it developed an F7 error code that does not allow any of the keypad to be used. Clock still works fine. I have tried hitting Clear/Off key and powering down the oven but code comes back.
Any thoughts on how to fix this?
aj
  #24 (permalink)
Old 04-30-2008, 01:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
aj,
The problem with your oven caused by one or more stuck pads on the control panel.
- The part number for the control panel (white) is AP3160621
Here are the break down diagrams for the GE oven Model JTP56WD1WW
__________________
  #25 (permalink)
Old 04-30-2008, 04:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Jane,
The "F3" error code means the oven temperature sensor (#14 on the break down diagram) is "open".
Locate the sensor plug at the control board and measure the sensor resistance. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong then you have to pull the range, remove the rear cover and measure the sensor resistance at the sensor plug.
If the reading is wrong - replace the oven temperature sensor.
If the reading is correct - check the wire harness.
If the sensor resistance at the control board is correct then check the plug and if there is nothing wrong - the control board has to be replaced.
- The part number for the oven temperature sensor is AP2831584
The control board (aka clock) is no longer available.
Here are the break down diagrams for the Thermador range Model GSC30CVWC
__________________
  #26 (permalink)
Old 06-30-2008, 06:19 PM
todmngd todmngd is offline
Junior Member
todmngd is on a distinguished road
Default Kenmore (Frigidaire) Error Code F10
My stove continuously flashes F10 as the oven heats up. Sears repair said it was a bad display. I personnally didn't think this was right but they are supposed to be the experts. I cannot find the error codes for my model of stove 790.36679400. I beleive it is a run away temp. Because after the stove is off the code will continue to appear. Any thoughts on this is greatly appreciated.
  #27 (permalink)
Old 07-04-2008, 08:57 PM
aulfgar aulfgar is offline
Junior Member
aulfgar is on a distinguished road
Default
I think this question was answered already, but does F2 mean a runaway temperature sensed for a Kenmore Classic Grille? I would give the model number or appliance number but I can't seem to find it, it is very old however looks like mid 70's decor.
  #28 (permalink)
Old 07-05-2008, 06:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
todmngd,
If the "F10" appears while the range is in "time of the day" mode then the problem is a bad EOC.
If it appears in the "cook" mode then the oven temperature sensor has to be checked first. It could be a bad wire harness and/or sensor plug.
- The part number for the EOC is AP3790798
- The part number for the oven sensor is AP3363354
__________________
  #29 (permalink)
Old 07-05-2008, 06:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
aulfgar,
You are right, "F2" error code on older models means "runaway temperature".
__________________
  #30 (permalink)
Old 07-20-2008, 11:28 AM
w2002s w2002s is offline
Junior Member
w2002s is on a distinguished road
Default
I replace the clock timer on my frigidare wall oven ,the clock work . the buttom works , but no power to the elements
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
