Discuss
Oven Error Codes
 in
hello...I do not see the F7 error code for a GE JTP56WW1WW wall double oven on your list of GE
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
  #191 (permalink)
Old 07-09-2016, 02:57 PM
Junior Member
mountain1 is on a distinguished road
Default
hello...I do not see the F7 error code for a GE JTP56WW1WW wall double oven on your list of GE error codes. I do not also see the test you say is available on the error code page right below the list of brands to determine whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. Please assist
  #192 (permalink)
Old 07-11-2016, 10:42 AM
Junior Member
Default
Hello good folks at Appliance Parts Pros. I have a GE over under wall oven Model #JTP56WOW1WW. I am getting an F7 error code but on your list of error codes I do not see the F7 listed. Also the test you say that can determine whether the part needed (either the control panel or the control board) that you say is listed right at the bottom of the error codes listed is not there. Please assist and I appreciate your help.
  #193 (permalink)
Old 12-13-2016, 10:07 AM
Junior Member
Lohmars is on a distinguished road
Default
I am getting E1 F5 error code on my whirlpool oven when trying to run the self clean cycle. I think it has to do with the door latch from what I can find but what does that mean? How do I fix that?
  #194 (permalink)
Junior Member
Default E1f5
  #195 (permalink)
Old 12-13-2016, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to provide most accurate advice we need the complete model number of the oven.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #196 (permalink)
Old 12-14-2016, 08:05 AM
Junior Member
Default
E1 F5 error on my Whirlpool oven GS395LEGB, RH2810892
  #197 (permalink)
Old 12-14-2016, 01:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The cause of the problem could be: faulty door latch switch, faulty door latch motor, bad wiring or faulty control board.
In the model number, you posted is missing one or two characters on the end. It is very important for proper troubleshooting and parts information to have the model number completed. Please verify and repost it.
__________________
  #198 (permalink)
Old 03-19-2017, 09:36 AM
Junior Member
mlpetrozelli is on a distinguished road
Default Getting the F2E1 error from steam!
Hi guys, I have a Kitchenaide KERS807SSS01 that we accidentally spilled water onto the stovetop, which leaked into the electronics thus throwing errors. We opened up the front panel, used a hairdryer to dry both the membrane and display panel, vacuumed out the dust from the front circular vents below it and plugged it back in...no errors.
Yet now whenever we are baking something in the oven, the moment you open the door it throws a F2E1 stuck /shorted key error from the steam. Sometimes it shuts down automatically and you wait for the steam to clear FROM INSIDE the display! It almost seems as if the round holes above it that were clogged with dust are now clear but letting steam into the unit thus throwing errors because of the steam hitting it.
  #199 (permalink)
Old 03-19-2017, 05:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely the membrane switch was damaged by the spilled water. You may want to order the new part from Appliance Parts Pros and give it a try. You have nothing to lose due to their very friendly return policy.
The membrane switch Part number: AP6014094
Good luck and keep us posted.
__________________
  #200 (permalink)
Old 06-08-2017, 12:09 AM
Junior Member
McGear10 is on a distinguished road
Default
Thanks for error code reference.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Similar Threads
GE Oven error codes BobChurch Oven Repair (including Ranges and Cooktops) 3 09-02-2009 07:58 PM
oven error display codes mdj11faith Oven Repair (including Ranges and Cooktops) 1 09-02-2009 07:24 PM
GE oven error codes bdeinhardt@aol.com Oven Repair (including Ranges and Cooktops) 5 07-03-2009 12:41 PM
oven error codes cndybkr Oven Repair (including Ranges and Cooktops) 3 10-18-2008 09:18 PM
Error Codes Whirlpool Oven brummel Oven Repair (including Ranges and Cooktops) 0 08-25-2008 01:27 PM
