Discuss
Oven Error Codes
 in
Hi Mark, In order to provide the most accurate advise I need the complete model number of the unit. Gene.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #11 (permalink)
Old 01-16-2008, 04:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Mark,
__________________
  #12 (permalink)
Old 01-30-2008, 11:08 AM
Mar Mar is offline
Junior Member
Mar is on a distinguished road
Unhappy JennAire Stove has an error code of F9
Hi Gene,
Need further explanation on the definition of the F9 code - Door Latch. It says to check the door latch components. My stove door is locked. I tried turning the breaker off for a little over 2 minutes and turning it back on. That did not help. Do have any other advice on checking the door compenents? Thanks Mar
  #13 (permalink)
Old 01-30-2008, 09:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mar,
In order to provide the most accurate advise I need the complete model number of the range.
To unlock the door you can try to start the self clean as usual and then cancel it after 3 minutes. Sometime it works.
__________________
  #14 (permalink)
Old 02-02-2008, 06:00 PM
fredr fredr is offline
Junior Member
fredr is on a distinguished road
Default Jennair w156w
This came from CS Shepard. "
I have a Jenn-Air w156w wall oven at least 10 years old. According to the information on your website, I need part AP184967, the touchpad. However, in your picture of the part the plastic electronic ribbon is two-pronged. The one on my oven is one flat strip. Will this still work?"
My question is I have the same thing and have f-2 on the read out. DO I have to do what CS did and get this AP 184967 touch pad. I have a one flap strip also. Will this work for me too? Thanks, Fred
  #15 (permalink)
Old 02-12-2008, 06:56 PM
pat.cusack pat.cusack is offline
Junior Member
pat.cusack is on a distinguished road
Default
Interestingly before I bought a replacement I turned off the power and took the control off, just to see how easy it was. When the power is off for 5 minutes or so it does reset the error code. We've had it back twice, but not recently.
  #16 (permalink)
Old 02-12-2008, 07:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Fred,
The "F2" means the oven control senses runaway temperature and it has nothing to do with the touch pad.
The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
- The part number for the oven temperature sensor is AP204836
- The part number for the power relay board is AP3970864
Here are the break down diagrams for the Jenn Air oven Model W156W
__________________
  #17 (permalink)
Old 02-12-2008, 07:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Par,
Reseting power for a few minutes helps to eliminate about 15% of electronic control problems.
__________________
  #18 (permalink)
Old 03-09-2008, 06:58 PM
winston Bruce winston Bruce is offline
Junior Member
winston Bruce is on a distinguished road
Angry Winston
Jenn Air stove error code F5 the oven cuts off clock goes off comes back on and goes off again. Model #SVE47500W
  #19 (permalink)
Old 03-10-2008, 11:36 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Bruce,
Most likely the problem with your range is a bad Electronic Range Control (ERC) which has to be replaced.
- The part number for the ERC is AP367441
Here are the break down diagrams for the Jenn Air range Model SVE47500W
__________________
  #20 (permalink)
Old 03-10-2008, 02:03 PM
SMIMS SMIMS is offline
Junior Member
SMIMS is on a distinguished road
Default Frididaire Electric Range
My range had the F1 code reading. I see where it could be the clock/touch pad. My question is, would it affect the way the range works. I can program at 350 degrees and it will not turn off, the temp continues to rise. If I put on 170 degrees it continues to rise, then the F1 code shows up on my display.
Thank you for any information you can provide me with.
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
