Discuss
Oven Error Codes
 in
Originally Posted by Gene Keep us posted please. Gene. Received fan today and installed it. Oven up and running. Spec
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
  #181 (permalink)
Old 04-05-2013, 01:47 PM
Junior Member
Tucson Alan is on a distinguished road
Default
Quote:
Received fan today and installed it. Oven up and running. Spec sheet had info on thermal cutoff switch when fan fails. Just wish your shipping dept. had packed fan a little better. Broken plastic frame and trim pieces. Lucky it did not affect performance.
Alan
  #182 (permalink)
Old 04-05-2013, 04:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Alan. I'm glad it's up and running.
Regarding broken package you have to talk to the APP customer service. I do not work for APP. I'm just helping people like you as a volunteer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #183 (permalink)
Old 04-29-2013, 02:32 AM
Junior Member
bravo2510 is on a distinguished road
Default
This is very informative post. I came to know about the errors and this will surely help me in future as I am mad about cooking I usually go through some errors. Thank you
  #184 (permalink)
Old 07-12-2013, 02:56 AM
Junior Member
hannahjo is on a distinguished road
Default
Very helpful post! Thanks much for the oven repair tip!
  #185 (permalink)
Old 07-12-2013, 03:29 AM
Junior Member
martymande is on a distinguished road
Default
My Thermador PDR366ZS oven's blue heat lamp is flashing 4 times, the blue heat lamp is out. I need to replace that so I can see the second part of code. I cannot get the front panel off are there instructions or video to show this?
Also how do you know if it is an E or an F code?
  #186 (permalink)
Old 10-01-2013, 11:00 AM
Junior Member
sstark is on a distinguished road
Default
Quote:
Originally Posted by Admin / APP Team View Post
.... Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands....
I must be blind. I cannot find the "error code page" that has the "simple test." Could you provide a link?
Thanks!
  #187 (permalink)
Old 12-04-2013, 06:45 AM
Junior Member
kendfig11 is on a distinguished road
Default F1 error code on Maytag oven after replacing bake element
I have Maytag oven. Model number is CHE9800BCE. It's over 10 years old.
Three days ago, the bake element started to burn. Within a few minutes, the oven flashed the F1 error code. We turned off power to the oven and ordered a new bake element from AppliancePartsPros. I put that in yesterday with no problems.
When we turned on the power and attempted to heat up the oven using the bake function, the F1 error code flashed after two minutes. The bake element did not heat up at all. We tried this several times.
Even when we turn on power again and do not attempt to heat up the oven, the F1 error flashes after a couple minutes. And it continues to return a few minutes after pressing Cancel. The broil element also does not work. The burn elements on the top do still work.
Is there something wrong, then, with the touch pad as well? Could that have failed just at the same time that the bake element burned out?
The part is 12001607 (AP4009447), which does not appear to be carried by AppliancePartsPros.
  #188 (permalink)
Old 03-30-2015, 07:59 PM
Junior Member
mrgarcia is on a distinguished road
Default Hi
I am trying to replace the temperature gauge on my oven. After receiving the new gauge, I noticed that it has the start temperature needle pointed at 200 degrees but thanks to fix appliances for helping me
  #189 (permalink)
Old 04-17-2015, 10:57 PM
Junior Member
ApplianceQueen is on a distinguished road
Default
If it turns out you need that clock.. message me.. I may have one.. I have way too many old parts! =)
  #190 (permalink)
Old 05-13-2015, 09:12 AM
Junior Member
sosrepairsTO is on a distinguished road
Default
We might have that part available! If you need us to help you install it we can definitely sort you out. Give us a shout at SOS Appliance Repair or VIKING Appliance Repair and we'll do our best to help you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 01:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 07:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 07:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 09:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 02:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 02:10 PM
Similar Threads
GE Oven error codes BobChurch Oven Repair (including Ranges and Cooktops) 3 09-02-2009 06:58 PM
oven error display codes mdj11faith Oven Repair (including Ranges and Cooktops) 1 09-02-2009 06:24 PM
GE oven error codes bdeinhardt@aol.com Oven Repair (including Ranges and Cooktops) 5 07-03-2009 11:41 AM
oven error codes cndybkr Oven Repair (including Ranges and Cooktops) 3 10-18-2008 08:18 PM
Error Codes Whirlpool Oven brummel Oven Repair (including Ranges and Cooktops) 0 08-25-2008 12:27 PM
