| » Oven Error Codes |
Quote:
Gene. Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The closest error code I found is "1D11". If this is correct, then it means "runaway temperature".
The first thing you may want to do is measure the oven temperature sensor resistance. The normal reading suppose to be about 1100 Ohms at the room temperature. If the reading is incorrect, replace the oven sensor. If the reading is correct, replace the control board. - The oven sensor Part number: 12001656 - The oven control board Part number: 8507P331-60 Here are the breakdown diagrams and Replacement parts for Jenn-Air JER8885RCS JENNAIR COOKING | AppliancePartsPros.com Gene.
__________________
Quote:
Quote:
The area where I observed flame was clean and the display was normal. I need some help in troubleshooting GBS307PRB01 Last edited by stickyfingers : 03-23-2013 at 07:55 PM. |
Quote:
Double check everything and run it again. Any error code consists of 4 elements: "F" with a digit and "E" with a digit. All 4 elements are important for proper diagnosis. Here are the breakdown diagrams and Parts for Whirlpool GBS307PRB01 Wall Oven - AppliancePartsPros.com Gene.
__________________
Get F9 when using self clean only on top oven. Also fan in control module is inop. Door lock motor seems to continue to run until error code shuts down. Not sure if inop fan caused overheat of motor or it is just two separate issues. Oven works ok to cook but top module seems to get much hotter than we remember. Model PT956BM3BB GE
I have a double electric wall oven. Model #GBD307PRS01. Serial #XT2210725. It flashed an error of F2 E6 on the display then went blank. I can press buttons and hear a double beep but nothing comes on the display screen anymore. The oven will not power on either. From reading the post on here it seems as though I need to replace the control panel. However, there are several parts to the control panel. Would you know what part #I should order? Also, is there a special place to order from other than Whirlpool? Thanks for your help! |
| Display Modes | |
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
| Posted By | For | Type | Date | |
| Digg - Who dugg or blogged: Oven Error Codes | This thread | Refback | 01-01-2008 01:57 PM | |
| Digg - Oven Error Codes | This thread | Refback | 12-06-2007 07:29 PM | |
| Digg - Oven Error Codes | This thread | Refback | 10-15-2007 07:21 PM | |
| digg / postaholic / news / submitted | This thread | Refback | 08-15-2007 09:11 PM | |
| Digg - Oven Error Codes | This thread | Refback | 08-01-2007 02:15 PM | |
| Digg / News / Upcoming | This thread | Refback | 08-01-2007 02:10 PM | |
| GE Oven error codes | BobChurch | Oven Repair (including Ranges and Cooktops) | 3 | 09-02-2009 06:58 PM |
| oven error display codes | mdj11faith | Oven Repair (including Ranges and Cooktops) | 1 | 09-02-2009 06:24 PM |
| GE oven error codes | bdeinhardt@aol.com | Oven Repair (including Ranges and Cooktops) | 5 | 07-03-2009 11:41 AM |
| oven error codes | cndybkr | Oven Repair (including Ranges and Cooktops) | 3 | 10-18-2008 08:18 PM |
| Error Codes Whirlpool Oven | brummel | Oven Repair (including Ranges and Cooktops) | 0 | 08-25-2008 12:27 PM |
