Discuss
Oven Error Codes
 in
Sorry, I have been out. Yes I see I left the 1 off the end. 790.77489801 When I power the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
  #141 (permalink)
Old 04-29-2010, 08:40 PM
Junior Member
double bogey is on a distinguished road
Default
When I power the oven up, it (controller) buzzes, and clock flashes 12:00, but won't accept a setpoint. After about a minute, it beeps and flashes F11 code. When I reset, the "delay start" lite comes on. All buttons beep when pressed, but will not do anything. Looking for what F11 means, and any help I can get. Range is a few months out of warranty.
Ads By Google
  #142 (permalink)
Old 04-30-2010, 12:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
"F11" fault code means "Shorted keypad". There is no a separate keypad in this model and the correction is to replace the Electronic Oven Control (aka a clock/timer). It's recommended to replace it together with the overlay because it's glued on.
- The EOC Part number: AP4362413
- The overlay Part number: AP3767951
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #143 (permalink)
Old 04-30-2010, 12:52 PM
Junior Member
Default
Thanks Gene, I was afraid of that. Glad you could get the code, I would hate to change the controller only to find out it was a sensor or other inexpensive part.
  #144 (permalink)
Old 04-30-2010, 12:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #145 (permalink)
Old 05-05-2010, 08:56 PM
Junior Member
Default
I ordered a new control, and in the meantime I took the old control apart and cleaned it with electrical contact cleaner. I let it dry out several hours, and installed it. It started out with the same code, but we needed the cooktop for supper. After about an hour it started working. I will wait for the new part to come in, but if it keeps working, I won;t change it.
  #146 (permalink)
Old 05-05-2010, 09:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm afraid it's not going to last long. Keep the new part as long as possible.
__________________
  #147 (permalink)
Old 05-05-2010, 09:12 PM
Junior Member
Default
Ihats what I was thinking also.
  #148 (permalink)
Old 05-26-2010, 11:24 PM
Junior Member
regorp is on a distinguished road
Default kitchenaid Double Oven KEBS277YWH2
Greetins
I'm desperate for assistance. My oven stopped working. I get F1 code when reach designated temperture. Any advise of what to do?
Greatly appreciated
  #149 (permalink)
Old 06-04-2010, 02:18 PM
Junior Member
smitchell0269 is on a distinguished road
Default Whirlpool Errors
Hey Guys,
My parents just experience a lightning strike close to their home and a coorsponding electrical surge which knocked out a couple of their applicances in addition to several of their electrical devices.
My specific question is regading their Whirlpool Smooth Tope Oven/Range (Model # GR448LXPS1). Once the power was restored to their home the range began displaying a series of numbers so I made the assumption that the controller was bad and ordered a replacement from appliancepartspros.com but once installed it was still giving the same random numbers. I'm wondering if anyone might have an idea as to what the problem is and which part(s) need to be replaced. Below is a list of the numbers that continually flas on the display. Thanks in advance for the help.
Error Codes: 79 r 4, 999, 516, 820, 634, 170, 449, 541, 169, 263.
  #150 (permalink)
Old 06-04-2010, 06:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by smitchell0269 View Post
Hey Guys,
The numbers you posted not even close to a valid error codes listed in the Tech sheet.
The first thing I would do is measure the voltage at the range wall outlet and at the control board. It suppose to be 240 VAC at the outlet and 120 VAC between P4-1 (white wire) and P4-3 (black wire). Make sure the black wire is hot and the white wire is neutral.
If the voltage reads OK, try to set the clock and use the Bake and Broil. Post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 01:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 07:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 07:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 09:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 02:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 02:10 PM
Similar Threads
GE Oven error codes BobChurch Oven Repair (including Ranges and Cooktops) 3 09-02-2009 06:58 PM
oven error display codes mdj11faith Oven Repair (including Ranges and Cooktops) 1 09-02-2009 06:24 PM
GE oven error codes bdeinhardt@aol.com Oven Repair (including Ranges and Cooktops) 5 07-03-2009 11:41 AM
oven error codes cndybkr Oven Repair (including Ranges and Cooktops) 3 10-18-2008 08:18 PM
Error Codes Whirlpool Oven brummel Oven Repair (including Ranges and Cooktops) 0 08-25-2008 12:27 PM
