Discuss
Oven Error Codes
 in
Failure codes for different models can be different. According to the Failure Codes list for PGR models, the problem most
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #111 (permalink)
Old 10-19-2009, 05:40 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Failure codes for different models can be different. According to the Failure Codes list for PGR models, the problem most likely is a bad Electronic Range Control (ERC).
- The ERC Part number: AP3392876
__________________
  #112 (permalink)
Old 10-20-2009, 02:33 PM
cgeljones cgeljones is offline
Junior Member
cgeljones is on a distinguished road
Exclamation F7 error
This code is not listed under the GE built in oven. I see it under others though, is it the same?
  #113 (permalink)
Old 10-20-2009, 03:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Error codes are very different for different makes and models. What is the complete model number of the oven?
__________________
  #114 (permalink)
Old 10-28-2009, 03:02 PM
barbboy barbboy is offline
Junior Member
barbboy is on a distinguished road
Default
I just ordered a replacement controller/clock for my Maytag Oven, since the existing one kept beeping randomly and the oven would not stay on. (But no fault code)
I installed the replacement part, and within 5 minutes it showed an F1 fault. New part from this site, right out of the box. Before I exchange it for another board, is there something else that I should be checking? Is it possible that something else is making it do a F1 fault or did I just get a dud?
Maytag model MGR574ADW
Barb
  #115 (permalink)
Old 10-28-2009, 06:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Barb,
What is the part number of the control board you ordered?
__________________
  #116 (permalink)
Old 10-29-2009, 07:36 AM
Junior Member
Default
Gene,
I ordered Part Number AP4309072 (W10162787) CNTRL-ELEC as was suggested on this board.
Barb
  #117 (permalink)
Old 10-29-2009, 03:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Barb,
The part number is correct and it looks like the control board is defective. They should replace it under the part warranty.
__________________
  #118 (permalink)
Old 11-03-2009, 07:35 AM
aja8888 aja8888 is offline
Junior Member
aja8888 is on a distinguished road
Default
Hi Gene:
Thanks for all you are doing here helping people!
We have a Frigidaire electric range model GLEF378CSB and the oven is not working. No codes are thrown and the touch panel "looks" like it is working (all functions) but no heat in the oven or broiler. A tech was out several months ago and said the EOC needs to be changed out for the sum of $450!. Now, if no codes are thrown, is this a possibility?
Thanks,
Tony
  #119 (permalink)
Old 11-03-2009, 04:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by aja8888 View Post
Hi Gene:
Thanks,
Tony
Tony,
Thank you for your good words.
Your question answered here: Frigidaire Range Oven Not Working
__________________
  #120 (permalink)
Old 11-03-2009, 04:52 PM
Junior Member
Default
Thanks Gene. I will get to it.
Tony
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
