Discuss
Oven Error Codes
 in
On 09-30-2007 Sailin wrote: > Oven Codes - Thank you for the oven codes. I do not see F7-
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #91 (permalink)
Old 07-16-2009, 10:27 PM
rodrigt rodrigt is offline
Junior Member
rodrigt is on a distinguished road
Default
> Oven Codes - Thank you for the oven codes. I do not see F7-E0 under Kitchenaid.....do you have additional information?? Thank you in advance!
Then on 10-04-2007 Admin / APP Team responded:
> This file explains F7-E0 code in detail.
(A link to: https://secured.whirlpool.com/Servic...LE/4317302.PDF )
Thank you, that was very helpful! My KitchenAid KESC307-HBS6 electric range (about 6 years old) suddenly showed up with an F7:E0 error code – Invalid latch switch reading – Check latch switch. And, adding to the fun, repeated testing showed the problem to be intermittent.
I would have never thought that the red plastic part would absorb enough moisture to become conductive and cause a false signal. In my circa 2003 electric stove the Latch Switch assembly was located in the top/center-rear part of the stove (after disconnecting the power cord and removing rear cover). The red plastic (connector holder) part slid out to the right, to unplug from the Latch Switch’s (two) terminals.
Fortunately this red thing provided an easy cut-point, to separate the two connectors (being shorted out, according to the above link). For this I held the red plastic part in one hand and labored with a fine-tooth hacksaw. Next I filled down the cut area and wrapped the resulting two red parts with electrical tape and plugged them back in – hoping this is the end of the F7-E0 gremlin.
PS- AppliancePartsPros has been of fabulous problem-solving help to me and my comments above are in the spirit of making a contribution – Thanks Guys!
  #92 (permalink)
Old 07-17-2009, 04:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Thank you for sharing your experience with us. Very instructive information. Good luck with your range.
__________________
  #93 (permalink)
Old 07-19-2009, 11:39 AM
dlandis1 dlandis1 is offline
Junior Member
dlandis1 is on a distinguished road
Default
Hey Gene,
Again, thanks for your help.
Per the instructions your provided, I was able to verify the wire harness was fine. I volt metered out the 1 and 2 pins on the ESEC board and it was not operating between 4 and 12 volts. I replaced the board yesterday and that has resolved both the F5 and F20 error.
Thank you again!! You saved me a ton in having it repaired.
  #94 (permalink)
Old 07-20-2009, 10:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad to hear it. Good luck with your range.
__________________
  #95 (permalink)
Old 07-23-2009, 08:07 AM
ranchingal ranchingal is offline
Junior Member
ranchingal is on a distinguished road
Default Kenmore 911.9598891
I attempted to use my broiler and oven in the last two days. Kept gettin "F5" error message. I tried this morning and the oven appeared to be preheating. What's the deal?
  #96 (permalink)
Old 07-23-2009, 01:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If this error code will return I would replace the control board (aka a clock).
- The clock Part number: AP2022868
__________________
  #97 (permalink)
Old 07-29-2009, 09:07 AM
olallavet olallavet is offline
Junior Member
olallavet is on a distinguished road
Default
I did not have an error code on my GE JTP11WP oven but the cold temperature registered 150 and the hot temps were off similarly. Replacing the temp probe, I got error code 3. Reversing the leads made the code disappear but the cold temp is now 280. The sales/tech persons confirmed I had the correct sensor. Where should I look now.
David
  #98 (permalink)
Old 07-29-2009, 02:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
David,
Most likely the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer.
Here are the breakdown diagrams and Replacement parts for GE JTP11WP | AppliancePartsPros.com
__________________
  #99 (permalink)
Old 07-29-2009, 03:09 PM
Junior Member
Default
Thanks for your response. I called for a replacement clock. The price is $ 280.00. I think I'll just replace the unit for that price.
Thanks again.
angie
  #100 (permalink)
Old 09-27-2009, 06:43 PM
appliance world appliance world is offline
Junior Member
appliance world is on a distinguished road
Default
whirlpool model# rbs305pdq12 getting an error code e1-f1
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
