Discuss
JES9800AAB burner replacement
 in
Our glass cooktop cracked and water may have cause the a burner near the crack to short as I saw
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » JES9800AAB burner replacement
  #1 (permalink)
Old 05-06-2011, 09:53 AM
Junior Member
Idratherbefishn is on a distinguished road
Default JES9800AAB burner replacement
Brand: Jenn-Air   Age: 5 - 10 years
Our glass cooktop cracked and water may have cause the a burner near the crack to short as I saw a flash and heard a pop while wiping down the cook top with the burner still on. I replaced the burner but the new one still doesnot work. Is there a circuit breaker attached to the burner that I am not aware of that needs to be reset? All the other burners work fine.
  #2 (permalink)
Old 05-06-2011, 11:00 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Fishn,
No, there's not a "circuit breaker" in the burner assembly or wiring harness.
I'd have to think, you also shorted the burner switch for that burner, or have a crossed or damaged wire, as well.
If you could supply which burner failed/shorted, we could get you the test information and possible parts needs, if you'd like.
Good Luck,
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-11-2011, 02:23 PM
Junior Member
Default Reply to burner model number
Quote:
Originally Posted by Joe / APP Team View Post
Fishn,
Good Luck,
Good Luck,
The model for the burner I replaced was 12002146 Whirlpool.
  #4 (permalink)
Old 05-11-2011, 04:26 PM
Senior Expert
Default
Idratherbefisshn,
Thats not quite what I had in mind,
Which burner, right front , right rear, etc.
What size burner, 9" dual burner, 6" dual burner, etc.
I'll try and figure it out.
Thanks,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 05-12-2011, 08:45 AM
Senior Expert
Default
OK, as best I can tell,
You replaced the
ELEMENT, (6`` RADIANT) 1200W Part number: AP4009117
MPN 12002146 / 74008573
If you need the burner infinite switch it should be, Part number: AP4088188
MPN 703650.
You can check the infinite switch circuits and voltages with a meter.
With the switch in the "ON" position and the wires off you should be able to read a "closed" circuit between L1 and H1 and L2 and H2 contacts on the switch.
With power applied to the range, and wires on the switch(this is a "live" voltage test so be careful) and the switch in the ON position you should read 240 VAC across L1 and L2 terminals(power in) and the H2 to H1 terminals(power out) on the switch.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jen Air JEC 9530 ADB Burner replacement Bill Gordon Oven Repair (including Ranges and Cooktops) 9 05-15-2012 10:19 PM
KitchenAid Burner Replacement vespa_1 Oven Repair (including Ranges and Cooktops) 1 12-03-2009 05:14 AM
burner replacement kcnbear Oven Repair (including Ranges and Cooktops) 0 09-19-2009 03:31 PM
burner replacement jamie1234 Oven Repair (including Ranges and Cooktops) 2 09-07-2009 03:22 PM
Ceramic top burner replacement AHC Oven Repair (including Ranges and Cooktops) 3 12-09-2008 01:29 PM
