I have a Maytag oven model #SVD486006 and when I close the door it springs back open about 1 inch. I have changed the hinges, hinge recepticals and the door seal gasket. (its not the new gasket keeping it open). I can not see anything bent or warped. Any ideas? Thanks
Per the Mayatg Technical bulletin (attached to the reply) the correction is to install the door hinge kit. - The door hinge kit Part number: AP4009106
