taberah
#1 Posted : Wednesday, May 4, 2011 3:24:30 PM(UTC)
taberah
Have this wall oven almost new from Lowes but discovered the broil element will not come on. I checked the element is good with meter and by switching it with the bake one - it glowed well. The terminals are on solid but it is not getting power from the controls. The broil light comes on when pushed on the panel and all timer controls look OK but I do not hear any relay tripping when broil is pressed.
I was going to purchase a new timer/clock with all the electronics and not the front control panel. Hopefully I can move over the wires and strips and get it working.
Does this sound like the right diagnosis and repair - or are there other suggestions?
thanks
#2 Posted : Wednesday, May 4, 2011 5:51:55 PM(UTC)
Yes, you are on the right track. The new clock/timer should fix the problem.
- The clock/timer Part number: AP3778485
Need help with diagnosis - bake and broil not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/7/2022 6:29:02 AM(UTC)
Bake and Broil not working (Oven Repair (including Ranges and Cooktops))
by Hankrosey 10/24/2013 4:07:46 PM(UTC)
BAKE and broil not working in top oven (Oven Repair (including Ranges and Cooktops))
by cksanabria 1/29/2013 3:03:08 PM(UTC)
Bake/Broil not working (Oven Repair (including Ranges and Cooktops))
by Puckhw7 3/27/2012 8:06:43 PM(UTC)
Bake Broil Not Working (Oven Repair (including Ranges and Cooktops))
by totab2@gmail.com 3/23/2012 12:46:07 AM(UTC)
Samsung bake and broil not working (Oven Repair (including Ranges and Cooktops))
by sunshineb 12/11/2011 9:56:10 AM(UTC)
gemini double oven top broil not working (Oven Repair (including Ranges and Cooktops))
by jeff w 2/20/2011 7:13:00 AM(UTC)
bAKE & BROIL NOT WORKING (Oven Repair (including Ranges and Cooktops))
by ahmed123 8/14/2010 11:59:46 AM(UTC)
Frigidaire Bottom Oven Broil not working (Oven Repair (including Ranges and Cooktops))
by Twn333 3/17/2010 1:59:59 PM(UTC)
Oven bake/broil not working after bake element replacement (Oven Repair (including Ranges and Cooktops))
by J Justin 11/5/2009 1:29:07 PM(UTC)
by leunkx1 3/18/2009 3:52:22 PM(UTC)
