Discuss
Error Code F34 But Sail Switch Is OK
 in
Have an early 2000 Thermodor C302U that displays error code F34. Sail switch is functioning and has been tested for
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Error Code F34 But Sail Switch Is OK
  #1 (permalink)
Old 05-04-2011, 07:07 AM
Junior Member
RWG0313 is on a distinguished road
Default Error Code F34 But Sail Switch Is OK
Model Number: C304   Brand: Thermador   Age: 5 - 10 years
Have an early 2000 Thermodor C302U that displays error code F34. Sail switch is functioning and has been tested for continuity. Connection at display board was inspected, in addition the terminals were jumped out to simulate closure of the sail switch. All has still resulted in a F34 error code.
It is significant to note that this error code has occurred after replacement of the relay board which was replaced due to failure of the circuiting/pins at two harnesses located near the transformer.
Our question on this subject centers on how the display board interfaces with the relay board and should we be looking for a defect in the display board or possibly a problem with the new relay board.
Ads By Google
Related Models
Whirlpool C3057X0
Whirlpool C3057^0
Jenn-Air C306 Surface Unit - Ddraft Ele
Jenn-Air C306-C Surface Unit - Ddraft Ele
Hoover C3077
Crosley C31000PAA Range - F/s Std Gas
Crosley C31000PAAD Range - F/s Std Gas
Crosley C31000PAT Range - F/s Std Gas
Crosley C31000PATP Range - F/s Std Gas
Crosley C31000PAW Range - F/s Std Gas
Crosley C31000PAWD Range - F/s Std Gas
Crosley C31000PAWP Range - F/s Std Gas
Crosley C31100PAA Range - F/s Std Gas
Crosley C31100PAV Range - F/s Std Gas
Crosley C31100SAA Range - F/s Std Gas
Crosley C31100SAAP Range - F/s Std Gas
Crosley C31100SAT Range - F/s Std Gas
Crosley C31100SATP Range - F/s Std Gas
Crosley C31100SAW Range - F/s Std Gas
Crosley C31100SAWP Range - F/s Std Gas
Crosley C31103SAA Range - F/s Std Gas
Crosley C31103SAT Range - F/s Std Gas
Crosley C31103SAW Range - F/s Std Gas
Crosley C31113WAA Range - F/s Std Gas
Crosley C31113WAAP Range - F/s Std Gas
Crosley C31113WAB Range - F/s Std Gas
Crosley C31113WAT Range - F/s Std Gas
Crosley C31113WATP Range - F/s Std Gas
Crosley C31113WAV Range - F/s Std Gas
Crosley C31113WAVP Range - F/s Std Gas
Crosley C31113XAA Range - F/s Std Gas
Crosley C31113XAT Range - F/s Std Gas
Crosley C31113XAW Range - F/s Std Gas
Crosley C31315VAM Range - F/s Std Gas
Crosley C31315VAV Range - F/s Std Gas
Crosley C31315VBM Range - F/s Std Gas
Crosley C31315VBQ Range - F/s Std Gas
Crosley C31315VBV Range - F/s Std Gas
Crosley C31315XBT Range - F/s Std Gas
Crosley C31315XBW Range - F/s Std Gas
Whirlpool C3157W0
Whirlpool C3157^0
Jenn-Air C316 Surface Unit - Ddraft Ele
Jenn-Air C316-C Surface Unit - Ddraft Ele
Jenn-Air C316B Surface Unit - Ddraft Ele
Jenn-Air C316B-C Surface Unit - Ddraft Ele
Jenn-Air C316W Surface Unit - Ddraft Ele
Jenn-Air C316W-C Surface Unit - Ddraft Ele
Whirlpool C3257W0
Whirlpool C3257^0
Whirlpool C3357^0
Whirlpool C3408B0
Whirlpool C3408B1
Whirlpool C3408B2
Whirlpool C3457X0
Whirlpool C3457X1
Whirlpool C3457^0
Whirlpool C3457^1
Magic Chef C3510PVV Range - F/s Std Ele
Magic Chef C3521WRV Range - F/s Std Ele
Magic Chef C3521XRA Range - F/s Std Ele
Magic Chef C3521XRW Range - F/s Std Ele
Magic Chef C3523WVA Range - F/s Std Ele
Magic Chef C3523WVV Range - F/s Std Ele
Magic Chef C3542XRA Range - F/s Std Ele
Magic Chef C3542XRL Range - F/s Std Ele
Magic Chef C3542XRW Range - F/s Std Ele
Magic Chef C3581VRV Range - F/s Std Ele
Magic Chef C3581VUV Range - F/s Std Ele
Magic Chef C3581XRA Range - F/s Std Ele
Magic Chef C3581XRW Range - F/s Std Ele
Thermador C36
Hoover C3820--- Extr - W/fix & Rot Brush,tempest
Magic Chef C3842XRA Range - S/c F/s Ele
Magic Chef C3842XRL Range - S/c F/s Ele
Magic Chef C3842XRW Range - S/c F/s Ele
Magic Chef C3862VYV Range - S/c F/s Ele
Magic Chef C3862XYB Range - S/c F/s Ele
Magic Chef C3868VYV Range - S/c F/s Ele
Magic Chef C3882VRV Range - S/c F/s Ele
Magic Chef C3882VVV Range - S/c F/s Ele
Magic Chef C3882XRA Range - S/c F/s Ele
Magic Chef C3882XRB Range - S/c F/s Ele
Magic Chef C3882XRW Range - S/c F/s Ele
Magic Chef C3882XVA Range - S/c F/s Ele
Magic Chef C3882XVW Range - S/c F/s Ele
Magic Chef C3888VRV Range - S/c F/s Ele
Magic Chef C3888VVV Range - S/c F/s Ele
Magic Chef C3888XRA Range - S/c F/s Ele
Magic Chef C3888XRW Range - S/c F/s Ele
Magic Chef C3888XVA Range - S/c F/s Ele
Magic Chef C3888XVW Range - S/c F/s Ele
Hoover C4275--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C4277--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C4279--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5023--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5025--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5027--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5029--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5031--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5033--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5035--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5037--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5039--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5041--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C5122
Amana C52B Room Air Conditioner
Maytag C5AALWH Freezer - Chest
Maytag C5ABLWH Freezer - Chest
Maytag C5H  Freezer - Chest
Maytag C5J Freezer - Chest
Hoover C6075--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C6077--- Coml - Access,burnisher,floor Mch,wet/dry
Amana C6412301 Misc / Accessory
Amana C64TMA Mwave - Cntrtp / Stand Alone
Amana C65T Mwave - Cntrtp / Stand Alone
Magic Chef C6892XVS Range - S/c S/i Ele
Maytag C6D  Freezer - Chest
Maytag C6D5  Freezer - Chest
Maytag C6E4  Freezer - Chest
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door switch/error code E41 sthrash40 Washer Repair 3 02-17-2013 07:46 PM
LG error code OE - drain error JPotter Washer Repair 0 04-01-2011 07:20 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
cannot get rid of error code C4 donna58 Dishwasher Repair 4 02-22-2009 05:30 PM
F3 Error Code Eva Oven Repair (including Ranges and Cooktops) 1 02-18-2008 11:27 AM
