Hi and thanks in advance for any help you can offer. Have Whirlpool Gold Accubake Duo range/oven traditional slide in to counter that is awesome. Wife loves it. Dont want to replace if don't need to. Problem: oven will sometimes not turn off after baking. Intermittent - not regular. Seems to be when heating above 400 but not 100% sure that is so. Also, when baking, at higher temperatures, display flickers and ultimately goes out. Can get it back by wiggling control panel/top part of oven display, but not steady. Only when it is not baking does it display 100% of the time. Lastly, oven auto clean doesn't work - get error code F5. Have searched all through the forums to see what might be the issue and it appears control is the issue, but not sure I understand which parts might be the main culprit. I really do appreciate your help. Thanks, John.
