Discuss
upper oven not working
 in
The elements in the upper oven will not heat. This began after a self clean cycle. The lower oven works
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » upper oven not working
  #1 (permalink)
Old 11-03-2007, 10:13 AM
drembo drembo is offline
Junior Member
drembo is on a distinguished road
Default upper oven not working
Model Number: ct227n   Brand: Thermador   Age: More than 10 years
The elements in the upper oven will not heat. This began after a self clean cycle. The lower oven works fine. The convection fan in the upper oven works. The digital readout for the upper oven selector and temperature seems dim compared to the working lower oven. The elements for the upper oven test OK. The upper oven readout says the oven is heating but the elements do not warm up.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not working-Stovetop working Jame Oven Repair (including Ranges and Cooktops) 8 10-08-2008 10:08 AM
upper and lower burners not consistent artkat Oven Repair (including Ranges and Cooktops) 0 09-28-2007 03:29 PM
Norge overflows on the upper side FEROIZ Washer Repair 1 09-19-2007 06:01 PM
Double Oven--Main oven not working bccavanaugh Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:22 PM
oven not working Charlie Oven Repair (including Ranges and Cooktops) 0 09-02-2007 08:17 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
