Discuss
Aluminum wiring to cooktop
 in
I just took out my circa 1987 Jenn Air downdraft cooktop to replace with a new GE. Though the house
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Aluminum wiring to cooktop
  #1 (permalink)
Old 01-22-2009, 06:14 PM
KingBiscuit KingBiscuit is offline
Junior Member
KingBiscuit is on a distinguished road
Default Aluminum wiring to cooktop
Brand: GE   Age: Less than 1 year
I just took out my circa 1987 Jenn Air downdraft cooktop to replace with a new GE. Though the house was built in '87, the wiring looks to be aluminum. The old cooktop was just connected with wire nuts (copper to aluminum).
Is it okay to leave this aluminum wire in place? If so, how best to connect to the copper?
Also, the existing wire and flexible metal conduit are too short to reach the new cooktop. If there's no slack available on the wire, I may need to put in a junction box either inside the cabinet or in the crawlspace below.
Advice appreciated...
-KB
  #2 (permalink)
Old 01-23-2009, 04:44 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
I would suggest you replace the aluminum wire with copper.
Best to check your local electrical code.
Code may now specify a four wire hookup. Check the install directions for the unit, a ground strap has to be connected or disconnected in the stove depending on number of wires.
Check out these pages
New Page 1
Aluminum Wiring Twist-on Connector Debate about the Ideal 65 "Twister" for Aluminum Wiring Repair
If you do decide to put in a junction box, make sure you:
1. Use certified Al/Cu connectors
2. Cut back the aluminum wire to make sure you have clean wire
3. Use Alumilox goop available under a number of different names but it prevents oxidation of the Al wire
4. Use a metal junction box
5. Make sure you have some slack in the wire in case you have to re-splice in the future
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn air wiring cooktop dwndrft wiring Q Pat_repairingstuff Oven Repair (including Ranges and Cooktops) 0 11-23-2009 04:27 PM
GE cooktop burner receptacle wiring cbprincipal Oven Repair (including Ranges and Cooktops) 3 08-15-2009 11:08 AM
Need help or wiring diagram for reconnecting cooktop Cooked out Refrigerator & Freezer Repair 2 07-31-2009 05:36 PM
Aluminum foil melted to ceramic cooktop HELP! bleweyz39 Oven Repair (including Ranges and Cooktops) 0 05-04-2009 04:42 AM
F'aire dual element cooktop replacement part wiring todd gilson Oven Repair (including Ranges and Cooktops) 0 01-21-2009 10:15 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
