| » Cannot set temperature on oven |
Model Number: gles388dqb Brand: Frigidaire Age: 1 - 5 years
I cannot set a meaningful temperature on the oven. Any value over 300 causes a display of 288 degrees. The oven will come on but seems to be overheating. If I set the temp to 250, I get 250 on the display, though I do not know if it heats to 250.
I get the same symptom with Conv Bake, Bake, Broil. I turned off the power for 2 minutes and still have the same problem. Is this a controller or a sensor? Where can I get a service manual? I think I need one. Ads By Google Related Models |
I fixed my oven.
288 is Celsius for 550 Fahrenheit which is the maximum temperature for this oven. Either my wife, or the dog, neither will admit doing this, pressed Broil for 7 seconds, then clean, then start. This toggles the temperature units. I repeated the sequence, I am back to Fahrenheit and the oven is working correctly again. |
Good job!
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| GE Oven temperature Bad | jeffdroy | Oven Repair (including Ranges and Cooktops) | 1 | 12-22-2009 11:01 PM |
| Oven will not keep temperature | daholloway | Oven Repair (including Ranges and Cooktops) | 1 | 12-18-2009 02:40 AM |
| Oven temperature | nada | Oven Repair (including Ranges and Cooktops) | 0 | 09-12-2009 11:43 AM |
| Oven Temperature Low | schredder | Oven Repair (including Ranges and Cooktops) | 1 | 09-30-2008 01:51 PM |
| GE Oven temperature | fivermillions | Oven Repair (including Ranges and Cooktops) | 1 | 12-25-2007 12:57 PM |
