display was working fine. hit bake button and display went black. no further display. cook top turns on. all buttons make a beep but still no display. turned power off, then back on no further results other than above. any ideas to get this display back up and running?
Originally Posted by: hylander display was working fine. hit bake button and display went black. no further display. cook top turns on. all buttons make a beep but still no display. turned power off, then back on no further results other than above. any ideas to get this display back up and running? Hylander, The digital display is an internal circuit in the control board. You'll need to replace the clock/erc assembly. Part number: AP4482320
Good Luck, :) :) :)
