I decided to to clean our Kitchen Aid oven for the first time by using the self cleaning feature. I believe the oven completed the cleaning as it did shut down after the 3 hours. However, the appeared to be clean in some areas but not in others. After cooling off we turned on the Oven. Everything appeared to be in working order we picked a temperature and the oven would not heat up and the LED diplay looked normal however the temp was stuck at Lo.
Is this an easy fix? part # and install guide.
thank you
