I just replaced element 8272565 (2500W) and the burner is still not working. I checked the burner range control and the voltage appeared at the switch contacts and the element contacts when the burner is turned on. Also when the burner is turned on, the cooktop light comes on and the SureSimmer light stays on even when pressed in. The three other elements work. Hopefully, you have some thoughts. Your guidance is appreciated!
