Discuss
How to change burner
 in
I need to change the RR burner on this unit. The burner number is 8523697. Could you please send me
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to change burner
  #1 (permalink)
Old 04-26-2011, 02:58 PM
Junior Member
Nader Naderi is on a distinguished road
Default How to change burner
Model Number: ARTC7003W   Brand: Amana   Age: 5 - 10 years
I need to change the RR burner on this unit. The burner number is 8523697. Could you please send me detail description of how to do it ?
Ads By Google
Related Models
Amana ARTC7003W Range - S/c S/i Ddraft Gas
Amana ARTC7021C Range - S/c S/i Ddraft Gas
Amana ARTC7021W Range - S/c S/i Ddraft Gas
Amana ARTC7114LL Range - S/c S/i Ddraft Gas
Amana ARTC7114WW Range - S/c S/i Ddraft Gas
Amana ARTC7121CC Range - S/c S/i Ddraft Gas
Amana ARTC7121WW Range - S/c S/i Ddraft Gas
Amana ARTC712ECC Range - S/c S/i Ddraft Gas
Amana ARTC712EWW Range - S/c S/i Ddraft Gas
Amana ARTC7511 E Range - S/c S/i Ddraft Gas
Amana ARTC7511E Range - S/c S/i Ddraft Gas
Amana ARTC7511LL Range - S/c S/i Ddraft Gas
Amana ARTC7511WW Range - S/c S/i Ddraft Gas
Amana ARTC7522CC Range - S/c S/i Ddraft Gas
Amana ARTC7522E Range - S/c S/i Ddraft Gas
Amana ARTC7522WW Range - S/c S/i Ddraft Gas
Amana ARTC7600E Range - S/c S/i Ddraft Ele
Amana ARTC7600LL Range - S/c S/i Ddraft Ele
Amana ARTC7600WW Range - S/c S/i Ddraft Ele
Amana ARTC8600E Range - S/c S/i Ddraft Gas
Amana ARTC8600LL Range - S/c S/i Ddraft Gas
Amana ARTC8600WW Range - S/c S/i Ddraft Gas
Amana ARTC8621CC Range - S/c S/i Ddraft Gas
Amana ARTC8621E Range - S/c S/i Ddraft Gas
Amana ARTC8621SS Range - S/c S/i Ddraft Gas
Amana ARTC8621WW Range - S/c S/i Ddraft Gas
Amana ARTE105BB Ref - Top Mount
Amana ARTE105BC Ref - Top Mount
Amana ARTE105BW Ref - Top Mount
Amana ARTE805BC Ref - Top Mount
Amana ARTE805BW Ref - Top Mount
Amana ARTS6650E Range - S/c S/i Ddraft Gas
Amana ARTS6650LL Range - S/c S/i Ddraft Gas
Amana ARTS6650WW Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 04-27-2011, 09:56 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Nader,
Here are the general instructions from the service manual as you requested.
Maintop Assembly
1. Turn power off to unit.
2. Open oven door and remove screws securing maintop to oven chassis, located on the out side edges of the maintop.
3. Raise the front edge of the maintop and pull forward approximately 6-inches.
4. Disconnect wire terminal plugs from the maintop assembly.
5. Lift maintop assembly from the oven chassis.
6. Reverse procedure to reinstall maintop assembly
Ribbon and Halogen Elements
1. Remove maintop assembly, see "Maintop Assembly" procedure, steps 1 through 5.
2. Remove screws securing element support bracket to maintop.
3. Label and disconnect wire terminals from element being replaced.
4. Release metal clips securing element to element support bracket.
5. Replace and reverse procedure to reinstall element.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bottom burner comes on when the oven is cold. after it heats up some the burner goes rmoyer Oven Repair (including Ranges and Cooktops) 0 03-14-2011 03:59 PM
Kitchenaid dual burner on ceramic stovetop will not turn on for the single burner schmidtjl@cni.net Oven Repair (including Ranges and Cooktops) 1 02-02-2011 11:47 AM
GE front load washerIf I change the front drum, do I need to change the back one too? rperanich Washer Repair 3 10-03-2010 05:54 AM
replaced stove top burner and infinite switch but burner still does not work rcaple Oven Repair (including Ranges and Cooktops) 1 09-23-2010 05:34 PM
High output burner ignitor ignites wrong burner mpopham Oven Repair (including Ranges and Cooktops) 1 04-07-2009 01:02 PM
