Kay W
#1 Posted : Monday, January 19, 2009 9:03:23 AM(UTC)
Kay W
I cannot figure out how to remove the heating element from this range. I have replaced them in the past on different makes; however the element does not plug or screw onto the wires. There is a metal clip that appears to be soldered onto the element and the actual electrical wires seem to be crimped onto the clip. Also, I know the model number I've listed is correct but every site I've checked says this number doesn't exist . Any help will be appreciated.:confused:
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
old Wall oven heating element problems (Oven Repair (including Ranges and Cooktops))
by shelliejh 12/6/2018 12:16:51 PM(UTC)
Need oven heating element GE # J320B1AV (Oven Repair (including Ranges and Cooktops))
by railfan777 10/18/2017 12:48:58 PM(UTC)
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
Oven Heating Element Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by this_is_nascar 10/4/2014 1:38:26 PM(UTC)
Replacing hotpoint oven heating element (Oven Repair (including Ranges and Cooktops))
by billsee 11/29/2013 6:37:57 AM(UTC)
Need help with range digital display after replacing oven heating element (Oven Repair (including Ranges and Cooktops))
by brewbaker 12/27/2012 3:11:57 PM(UTC)
new oven heating element will not heat (Oven Repair (including Ranges and Cooktops))
by Johnwg 7/15/2012 1:08:39 PM(UTC)
oven heating element popped (Oven Repair (including Ranges and Cooktops))
by howie b. 6/25/2012 3:26:59 PM(UTC)
Oven heating element (Oven Repair (including Ranges and Cooktops))
by snap683 3/15/2012 4:24:26 PM(UTC)
Oven Heating Element Split In Half! (Oven Repair (including Ranges and Cooktops))
by marinakiser 12/10/2011 4:36:11 PM(UTC)
G.E. oven heating element installation (Oven Repair (including Ranges and Cooktops))
by gloria Oliphant 10/24/2011 10:58:44 AM(UTC)
Oven Heating Element Cracked (Oven Repair (including Ranges and Cooktops))
by clramey 7/11/2011 3:00:12 PM(UTC)
Oven heating elements do not work (Oven Repair (including Ranges and Cooktops))
by Packy62 2/23/2011 8:57:48 AM(UTC)
How to replace oven heating element? (Oven Repair (including Ranges and Cooktops))
by ssananikone 1/7/2011 7:49:00 PM(UTC)
