| » whirlpool oven |
Model Number: gw395lep Brand: Whirlpool Age: Less than 1 year
Still need help with my error code on oven. It shows PF and the time but does not respond to touch pad. I tried to reset but same result. Do I need The control panal or the electronic control unit the control panel hooks up to. Thanks
Hi Gallo
Most likely the problem with your oven is a bad control panel. If your oven is less then a year old it should be under the manufacturer warranty , free of charge to you. If it's not under the warranty, I need you to post the complete model number of the oven to help you with the right part. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hi Gallo
You did not provide the color of the unit and I'm going to post the part numbers for all available colors. - The part number for the white control panel AP4261256 - The part number for the biscuit control panel AP4261905 - The part number for the black control panel AP4263577 - The part number for the stainless steel control panel AP4263578 Good luck. Gene.
__________________
| Display Modes | |
| Whirlpool Gas Oven | Bayardo | Oven Repair (including Ranges and Cooktops) | 1 | 11-05-2007 07:34 PM |
| Need help with Whirlpool oven | Kristie | Oven Repair (including Ranges and Cooktops) | 1 | 10-16-2007 12:09 PM |
| Whirlpool Oven | wyoming joe | Oven Repair (including Ranges and Cooktops) | 3 | 10-15-2007 10:54 AM |
| whirlpool oven does not work | bob zaveri | Oven Repair (including Ranges and Cooktops) | 1 | 08-30-2007 08:43 PM |
| Whirlpool Oven Element Bad? | kstidham | Oven Repair (including Ranges and Cooktops) | 1 | 08-02-2007 12:38 PM |
