I have a GE double electric wall oven model number JTP45BA1BB. The upper broiler does not work unless the oven is cold. If the upper oven is even slightly warm from using the oven (e.g. above 150 degrees), the upper broiler will not work. The upper and lower oven and the lower broiler work perfectly. The upper broiler also works when the oven is cold. There are no error codes, and the cooling fan cycles on and off properly. It seems like there is some kind of defective temperature sensor that prevents the upper broiler from working properly, but I do not have access to a wiring diagram from which I might be able to figure out which part is bad. Any help would be greatly appreciated.
