midnitemill
#1 Posted : Sunday, January 18, 2009 11:20:07 PM(UTC)
midnitemill
oven won't start in any mode (bake broil clean conv bake) but clock works, timer,and oven lite. I get no fail code so I'm stuck.
I also made sure that the control lockout was off.
Check door switch it was ok
Check the bake and broil element to see if I had continuity that was ok
I'm hoping someone can help me out?
#2 Posted : Monday, January 19, 2009 4:04:07 AM(UTC)
Here is your parts breakdown includes a wiring diagram
Model PLEB30S8CCC
Could be the switch,thermal Item 119 in the "Body" section.
Listed as F119 at the bottom of the list
Could be this is open (did not reset). Happens fairly often after a self clean cycle.
midnitemill
#3 Posted : Monday, January 19, 2009 3:56:58 PM(UTC)
midnitemill
Any way to test the switch??
And thanks for your help.
#4 Posted : Monday, January 19, 2009 6:10:43 PM(UTC)
Yes
Measure it with a meter
Just be sure to remove the wires from one side when checking it
There is a good sticky at the start of this forum
midnitemill
#5 Posted : Monday, January 19, 2009 9:01:16 PM(UTC)
midnitemill
Thanks for the quik reply. I will give it a test, and the sticky was a great
help
