| » GE Profie Artica Side by Side Freezer warm, fridge fine |
Model Number: PSI23SGRSV Brand: GE Age: 1 - 5 years
We have had our counter depth side by side GE Profile Artica Refrigderator going 3+ years without any problems. Last month our freezer got warm and thaw all the food ice when the freezer setting was set to 5 (0-9, 9 coldest).
What should I do to check and/or what's broken on this applicance? Thanks. Ads By Google Related Models |
Could not find any info on the listed Model Number.
Here is a breakdown for PSI23SGNAFBS, yours should be close. Model PSI23SGNAFBS Sounds like it may be a defrost problem. When you started it up and the evaporator fan was not working, it could be that the unit was in a defrost cycle. When it happens again remove the covers from the evaporator and check the coils. If they are heavily iced up it is a defrost problem (No Defrost). Causes could be control board, defrost thermostat (Open) or the defrost heater (Open - it is a glass type they go fairly often) My guess from your description is the the defrost thermostat is not opening (intermittent). During defrost the thermostat shuts off the heater when the ice is melted off the coils. The machine is still in defrost mode but the heater is off. If the thermostat does not open, too much heat is generated and will melt food.
__________________
| Display Modes | |
| Side by Side Fridge & Freezer Warm at top but cold on bottom | rosnik | Refrigerator & Freezer Repair | 7 | 04-06-2009 03:02 PM |
| kenmore fridge freezer side by side blowing warm | widgitfix | Refrigerator & Freezer Repair | 3 | 03-27-2009 01:46 PM |
| kenmore side by side fridge/freezer blows warm | widgitfix | Refrigerator & Freezer Repair | 3 | 03-23-2009 04:09 AM |
| Whirlpool Side-by-Side Freezer icing, fridge warm | barkwaffle | Refrigerator & Freezer Repair | 0 | 08-04-2008 07:57 PM |
| Kenmore Side by side getting warm freezer and fridge | tbonegrl | Refrigerator & Freezer Repair | 2 | 12-31-2007 02:52 PM |
