Discuss
Switch or Fan for Jenn air cooktop
 in
The fan switch turned on, and after so long would turn itself off. Sometimes after turning it to go on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Switch or Fan for Jenn air cooktop
  #1 (permalink)
Old 04-24-2011, 09:36 PM
Junior Member
CAMS is on a distinguished road
Default Switch or Fan for Jenn air cooktop
Model Number: CVE3401B   Brand: Jenn-Air   Age: More than 10 years
The fan switch turned on, and after so long would turn itself off. Sometimes after turning it to go on it wouldn't start and then after so long it would go on. Now it doesn't work at all. I am wondering if it is just the switch or fan? Thanks for help. Also, does anyone know how to get down into the middle of the cooktop to clean out the sides and under the filter?
Related Models
Jenn-Air CVE3401B SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE3401Q SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE3401W SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE407B SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE407B-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE407W SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE407W-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4180B SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4180B-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4180S SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4180S-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4180W SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4180W-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4270B SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4270B-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4270S SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4270S-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4270W SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4270W-C SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4370B SURFACE UNIT- DDRAFT ELE
Jenn-Air CVE4370W SURFACE UNIT- DDRAFT ELE
Jenn-Air CVEX4100B SURFACE UNIT- DDRAFT ELE
Maytag CVEX4100B19 20" ELECTRIC BUILT-IN DOWNDRAFT COOKTOP
Jenn-Air CVEX4100W SURFACE UNIT- DDRAFT ELE
Maytag CVEX4100W19 20" ELECTRIC BUILT-IN DOWNDRAFT COOKTOP
Jenn-Air CVEX4270B SURFACE UNIT- DDRAFT ELE
Maytag CVEX4270B19 43" ELECTRIC BUILT-IN DOWNDRAFT COOKTOP
Jenn-Air CVEX4270W SURFACE UNIT- DDRAFT ELE
Maytag CVEX4270W19 43" ELECTRIC BUILT-IN DOWNDRAFT COOKTOP
Jenn-Air CVEX4370B SURFACE UNIT- DDRAFT ELE
Maytag CVEX4370B18 43" ELECTRIC BUILT-IN DOWNDRAFT COOKTOP
Jenn-Air CVEX4370W SURFACE UNIT- DDRAFT ELE
Maytag CVEX4370W18 43" ELECTRIC BUILT-IN DOWNDRAFT COOKTOP
Jenn-Air CVG2420B SURFACE BASE UNIT- DDRAFT GAS
Jenn-Air CVG2420W SURFACE BASE UNIT- DDRAFT GAS
Jenn-Air CVG316B SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG316W SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4100B SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4280B SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4280S SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4280W SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380B SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380P SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380PD Surface Unit - Ddraft Gas
Jenn-Air CVG4380PF SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380PG SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380PK SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380PR SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380PU SURFACE UNIT- DDRAFT GAS
Jenn-Air CVG4380W SURFACE UNIT- DDRAFT GAS
Jenn-Air CVGX2423B SURFACE BASE UNIT- DDRAFT GAS
Maytag CVGX2423B18 34" GAS BUILT-IN DOWNDRAFT COOKTOP
Jenn-Air CVGX2423Q SURFACE BASE UNIT- DDRAFT GAS
Jenn-Air CVGX2423W SURFACE BASE UNIT- DDRAFT GAS
General Electric CVM1790SS1SS MICROWAVE
General Electric CVM2072SM1SS MICROWAVE
General Electric CVM2072SM2SS MICROWAVE
General Electric CVM2072SM3SS MICROWAVE
General Electric CVM2072SM4SS MICROWAVE
Thermador CVS30RB COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS30RS COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS30RW COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS36RB COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS36RS COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS36RW COOK "N" VENT DOWNDRAFT SYSTEM
Thermador CVS45RB COOK "N" VENT
Thermador CVS45RS COOK "N" VENT
Thermador CVS45RW COOK "N" VENT
Thermador CVSE36B COOKTOP
Crosley CW18C1 WASHER-TOP LOADING
Crosley CW18C1A WASHER-TOP LOADING
Crosley CW18C1H WASHER-TOP LOADING
Crosley CW18C3A WASHER-TOP LOADING
Crosley CW18C3W WASHER-TOP LOADING
Crosley CW18M4 WASHER-TOP LOADING
Crosley CW18M4A WASHER-TOP LOADING
Crosley CW18M4H WASHER-TOP LOADING
Crosley CW18P2A WASHER-TOP LOADING
Crosley CW18P2AC WASHER-TOP LOADING
Crosley CW18P2H WASHER-TOP LOADING
Crosley CW18P2W WASHER-TOP LOADING
Crosley CW18P2WC WASHER-TOP LOADING
Crosley CW18P6A WASHER-TOP LOADING
Crosley CW18P6H WASHER-TOP LOADING
Crosley CW18P6W WASHER-TOP LOADING
Crosley CW18T2A WASHER-TOP LOADING
Crosley CW18T2W WASHER-TOP LOADING
 CW2079CWD Washer
 CW2079CWD Washer
 CW2079CWN Washer
 CW2079CWN Washer
Crosley CW20C5A WASHER-TOP LOADING
Crosley CW20C5W WASHER-TOP LOADING
Crosley CW20C7A WASHER-TOP LOADING
Crosley CW20C7W WASHER-TOP LOADING
Crosley CW20M4A WASHER-TOP LOADING
Crosley CW20M6 WASHER-TOP LOADING
Crosley CW20M6A WASHER-TOP LOADING
Crosley CW20M8 WASHER-TOP LOADING
Crosley CW20M8A WASHER-TOP LOADING
Crosley CW20M8H WASHER-TOP LOADING
Crosley CW20M9A WASHER-TOP LOADING
Crosley CW20M9N WASHER-TOP LOADING
Crosley CW20P4A WASHER-TOP LOADING
Crosley CW20P4W WASHER-TOP LOADING
Crosley CW20P5A WASHER-TOP LOADING
Crosley CW20P5AC WASHER-TOP LOADING
Crosley CW20P5H WASHER-TOP LOADING
Crosley CW20P5HC WASHER-TOP LOADING
Crosley CW20P5W WASHER-TOP LOADING
Crosley CW20P5WC WASHER-TOP LOADING
Crosley CW20P6 WASHER-TOP LOADING
Crosley CW20P6A WASHER-TOP LOADING
Crosley CW20P6AC WASHER-TOP LOADING
Crosley CW20P6H WASHER-TOP LOADING
Crosley CW20P6W WASHER-TOP LOADING
Crosley CW20P6WC WASHER-TOP LOADING
Crosley CW20P8A WASHER-TOP LOADING
Crosley CW20P8AC WASHER-TOP LOADING
Crosley CW20P8AS WASHER-TOP LOADING
  #2 (permalink)
Old 04-25-2011, 05:11 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for JENN-AIR CVE3401B SURFACE UNIT- DDRAFT ELE | AppliancePartsPros.com
Here is a service manual
Download CVE3401.pdf
Cannot say if it is the switch or the motor.
Sounds more like the motor but that is just a guess.
You will have to pull them and check them with a meter.
If the switch checks out OK then it is probably the motor.
You could check the motor windings with a meter. It will tell you if the motor is gone if a winding is open. But if the windings check OK it does not eliminate the motor as being bad. Only way to check for sure is to do a live test with a line cord.
Note: I did find a bulletin that said there had been problems with the switches.
__________________
  #3 (permalink)
Old 04-26-2011, 10:09 PM
Junior Member
Default
Quote:
Originally Posted by denman View Post
Thank you for your help!
  #4 (permalink)
Old 01-13-2012, 12:42 PM
Junior Member
mrchgoparts is on a distinguished road
Default
JennAirFanSwitches
Quote:
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air cooktop fan switch wires jyrshen Oven Repair (including Ranges and Cooktops) 1 04-01-2011 04:25 AM
Jenn-Air Infinite switch wiring to next switch jb63129 Oven Repair (including Ranges and Cooktops) 1 10-25-2010 08:09 AM
switch tudp411 for Jenn Air cooktop tomjust Oven Repair (including Ranges and Cooktops) 1 12-06-2009 08:17 PM
Jenn-Air Cooktop fan switch removal malcolma Oven Repair (including Ranges and Cooktops) 0 11-22-2009 05:24 PM
GE Cooktop - Heat Switch + Select Switch dtshenoy Oven Repair (including Ranges and Cooktops) 3 06-06-2009 04:14 PM
