I have a Maytag model # SVD48600P oven and the door does not stay closed. I have changed the door hinges and as near as I can tell nothing is warped. The seal looks in good condition. I washed it and then put the oven on a 4 hour cleaning cycle to make sure it was formed properly but nothing helps. Help me!!!! Thanks Kerry
Sorry but I just do not see what the problem is. You say that "the door does stay closed" but that really is not a problem.
You may want to re-post with more info on what is happening. |
THIS FORUM IS DEAD!!!!!!! |
