| » Oven Door won't shut completely after replacing hinges |
Model Number: SVD48600P Brand: Jenn-Air Age: 5 - 10 years
Last year, we replaced a hinge on our oven door. This year, the other hinge broke, so we replaced it. Now, with both hinges replaced, the oven door does not shut completely. If we replaced both hinge receptacles (or hinge receivers) will the door shut properly? Do we also need to replace the door liner? If so, the oven door liner does not seem to be available anymore...(no longer available from your company & no longer available from Jenn Air).
Many thanks for your help. Blessings, Patti Champion Ads By Google Related Models |
Quote:
It's a bit late but, you should have replaced both the hinges and both receivers at the same time. Somethings to check : The area around the slots for the hinge and recievers on the oven front flange, make sure the area is not distorted(bent out) you can check the door liner, with a straight edge(yard stick will do) to make sure the liner isn't bent. Check the door seal/gasket, especially along the bottom for damage and tearing. If all is OK and after you install both hinge receivers wash the door seal with hot, soapy, water, and put the oven through a 4 hour self clean cycle, to help conform the seal to the oven opening. Part number: AP4090071 You should be OK from there, it will take some time and usage, but the door should eventually reach a satisfactory position (there will always be a slight difference at the top of the oven door). Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi Joe,
Thanks so much for your reply here. My dear hubby, when trying to fix this, moved the self-cleaning latch to the right...which messed up the self-cleaning process...and we are no longer able to use it. We are going to order the hinge receivers and hope for the best. I think the current receivers/receptacles are bent. Thank you, Patti |
Quote:
Patti, OK, order and install both the receivers, but you will need to expect at least a 1/2 to 3/4 in. difference, between the top and the bottom of the door. Without the high heat and the latch assembly tension, the seal wont conform, and the door will be out further at the top. I've never done this, but you may want to try setting a high bake temperature, close and brace the door with something and allow the cycle to run a few hours, lt may be helpful ???
__________________
Quote:
Pat, It's our pleasure Drop us a line anytime you need help. Happy Easter
__________________
| Display Modes | |
| oven door hinges | akchinn | Oven Repair (including Ranges and Cooktops) | 0 | 12-31-2010 12:44 PM |
| Door Will Not Completely Lock Shut | J.R. Fowler | Microwave Repair | 0 | 03-21-2010 09:20 AM |
| Oven Door Hinges | EEE | Oven Repair (including Ranges and Cooktops) | 3 | 01-27-2010 08:24 PM |
| Need tips for replacing door hinges | Flash13 | Dishwasher Repair | 0 | 12-01-2009 06:55 AM |
| Oven Door Hinges | GylanAllen | Oven Repair (including Ranges and Cooktops) | 3 | 12-19-2008 01:51 PM |
