My range top was flooded. All four burners started sparking. shut off power and dried everything out, let sit for 24hrs and turned breaker back on. All burners worked. Now back left burner (ELO) only clicks once when turned on, but does not ignite. Gas flows and burner can be lit manually and temp controlled by knob. Suspect ignitor is shorted but not sure. would love to have suspicion confirmed or redirected. Also any instructions on replacing ignitor if this is the case would be appreciated. Thank you.
