The ceramic top dual burner stays on high and will not cycle on the temperature control. Is this an element problem or infinate control? Thanks, Frank
Originally Posted by: murph21 The ceramic top dual burner stays on high and will not cycle on the temperature control. Is this an element problem or infinate control? Thanks, Frank Frank, That would be an Infinite Switch problem. Part number: AP3095444
You'll need to varify which switch you will need, but this will give you a place/part to start with. :) :) :)
