| » Range works/ stove ignitor works doesnt have gas |
Model Number: sf310pekq1 Brand: Whirlpool Age: 5 - 10 years
For a couple of months I've either waited about 5-10 minutes for oven to ignite even though the orange light has been on. I would bang the the bottom drawer which often made it ignite. sometimes i would light it manually. but now it seems no gas is coming out at all. orange light is still on and even with a lighter will not ignite. I am assuming I need the gas valve part ap3180965, but want to make sure before I pay100 dollars.
Quote:
Do Not start with the gas valve, It sounds more like a weak igniter. Part number: AP3129373 Just because the igniter glows, doesn't mean it is producing the amperage or voltage to the burner valve, to open it. If you have a multi meter or a clip on ammeter you can test the igniter. When the igniter is glowing you should be producing at least 3.2 amps and 3.2 VAC across the wires on the burner valve. anything lower will not open the bi metal switch inside the valve and the burner won't ignite. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Oven will not turn on, broiler works, stove top works | caewart | Oven Repair (including Ranges and Cooktops) | 1 | 06-20-2009 05:25 AM |
| Range Works But Oven Doesnt | cbr900rr | Oven Repair (including Ranges and Cooktops) | 1 | 06-03-2009 01:10 PM |
| Oven and broiler do not light, stove works, already replaced ignitor. Grrrr! | ncduckman | Oven Repair (including Ranges and Cooktops) | 1 | 02-24-2009 08:11 PM |
| Dryer Works, Doesnt Work, Works Again | timber284 | Dryer Repair | 0 | 08-01-2008 09:56 AM |
| GE oven stove top works, ignitor works, no gas flow in oven | mikeburton@cableone.net | Oven Repair (including Ranges and Cooktops) | 1 | 12-26-2007 07:09 PM |
