Oven Was Over Cooking And Would Not Turn Off Even If I Hit Cancel It Would Turn Back On And Flash Code. Had To Turn Circuit Breaker Off .changed The Main Control Board Part #wp8523665 Problem Still The Same . The Range Is Hardwired And Between The Kitchen Counter. The Bx Was Pulled Down Threw The Floor With Zero Slack After One Foot I Had To Just About Stand On My Head To To Change The Main Board .im Installing A Term Box And Cord Tomorrow So I Will Have Acess To The Back Of The Range I Will Check Wireing For A Short And Also The Sensor.if You Have Any Suggestions It Will Be Greatley Apreciated Bob
Originally Posted by: rcommando1 Oven Was Over Cooking And Would Not Turn Off Even If I Hit Cancel It Would Turn Back On And Flash Code. Had To Turn Circuit Breaker Off .changed The Main Control Board Part #wp8523665 Problem Still The Same . The Range Is Hardwired And Between The Kitchen Counter. The Bx Was Pulled Down Threw The Floor With Zero Slack After One Foot I Had To Just About Stand On My Head To To Change The Main Board .im Installing A Term Box And Cord Tomorrow So I Will Have Acess To The Back Of The Range I Will Check Wireing For A Short And Also The Sensor.if You Have Any Suggestions It Will Be Greatley Apreciated Bob Bob, You're on the right track, My guess is , you'll find a shorted wire or heating element, when you remove the rear panel and start looking. Do you remember what the fail code was? It would give us a better idea of where to start for possible failures. I'm sure you'll be OK, once you get access to the wiring. Good Luck, :) :) :)
