Discuss
HELP F1 code tried everthing!
 in
Jenn-Air Classic Range 5 YEARS OLD Model Number JES9860AAB Serial Number 17158809ZS Range keeps giving F1 – 7 error code
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » HELP F1 code tried everthing!
  #1 (permalink)
Old 10-30-2007, 04:10 PM
Junior Member
Anderseven is on a distinguished road
Default HELP F1 code tried everthing!
Model Number: JES9860AAB   Brand: Jenn-Air   Age: 1 - 5 years
Range keeps giving F1 – 7 error code …. Which means the oven will not function.
After a service call it was recommended that we purchase a new Control Panel for $360.00 and Labor of $131.00 to install. Since we can not afford this action I tried to fix it myself.
First I did a simple test to determine whether the ERC (Electronic Range Control or Clock) or the touch pad was defective when F1 error code was present.
This models does not incorporate the touch pad in to the ERC as a single assembly.
Disconnected power to the range by turning the power off to the range at the circuit breaker.
Gained access inside the control panel.
Disconnected the touch pad ribbon from the ERC.
Check to be sure there were no lose wires, or anything else that may cause a short when power was turned back on. Assembled the control panel back the way it was.
Turned the power back on.
The F1 code came back with it’s beeping sound.
I purchased a replacement ERC. AP3503208 (74007226) Clock, w/harness
And installed…however…F1 code still remains.
Disconnected oven temperature sensor, after finding out the ERC could generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This still resulted in the now forever F1 code.
SO… the oven sensor circuit checks okay, the touchpad/keyboard, does not seem to be the problem. I have installed a new ERC, all the wires are fine…….
PLEASE ANY ADVISE….ANY CLUES….THANKSGIVING IS ON THE WAY FAMILY COMING ETC.
THANKS FOR ANY HELP YOU CAN GIVE….
anderseven@aol.com
Ads By Google
Related Models
Jenn-Air JES9860AAB Range - S/c S/i Ddraft Ele
Jenn-Air JES9860AAS Range - S/c S/i Ddraft Ele
Jenn-Air JES9860AAW Range - S/c S/i Ddraft Ele
Jenn-Air JES9860ACB Range - S/c S/i Ele
Jenn-Air JES9860ACS Range - S/c S/i Ele
Jenn-Air JES9860ACW Range - S/c S/i Ele
Jenn-Air JES9860BAB Range - S/c S/i Ddraft Ele
Jenn-Air JES9860BAS Range - S/c S/i Ddraft Ele
Jenn-Air JES9860BAW Range - S/c S/i Ddraft Ele
Jenn-Air JES9860BCB Range - S/c S/i Ddraft Ele
Jenn-Air JES9860BCS Range - S/c S/i Ddraft Ele
Jenn-Air JES9860BCW Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BAB Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BAF Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BAQ Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BAS Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BAW Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BCB Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BCS Range - S/c S/i Ddraft Ele
Jenn-Air JES9900BCW Range - S/c S/i Ddraft Ele
General Electric JET1050A1 Counter top microwave
General Electric JET1050Y4 Counter top microwave
General Electric JET1060A1 Counter top microwave
General Electric JET1060A2 Counter top microwave
General Electric JET107001 Counter top microwave
General Electric JET108001 Counter top microwave
General Electric JET1110Y4 Counter top microwave
General Electric JET1120A1 Counter top microwave
General Electric JET1120A2 Counter top microwave
General Electric JET114001 Counter top microwave
General Electric JET1300A1 Counter top microwave
General Electric JET200001 Counter top microwave
General Electric JET200002 Counter top microwave
General Electric JET200003 Counter top microwave
General Electric JET200004 Counter top microwave
General Electric JET202001 Counter top microwave
General Electric JET2020D1 Counter top microwave
General Electric JET2020D2 Counter top microwave
General Electric JET2020D3 Counter top microwave
General Electric JET2020D4 Counter top microwave
General Electric JET203001 Counter top microwave
General Electric JET203002 Counter top microwave
General Electric JET203003 Counter top microwave
General Electric JET204001 Counter top microwave
General Electric JET208001 Counter top microwave
General Electric JET208002 Counter top microwave
General Electric JET208003 Counter top microwave
General Electric JET209001 Counter top microwave
General Electric JET2090D1 Counter top microwave
General Electric JET2090D2 Counter top microwave
General Electric JET2090D3 Counter top microwave
General Electric JET2090D4 Counter top microwave
General Electric JET210001 Counter top microwave
General Electric JET210002 Counter top microwave
General Electric JET210003 Counter top microwave
General Electric JET210004 Counter top microwave
General Electric JET211001 Counter top microwave
General Electric JET211002 Counter top microwave
General Electric JET2110H1 Counter top microwave
General Electric JET212001 Counter top microwave
General Electric JET212002 Counter top microwave
General Electric JET2120H1 Counter top microwave
General Electric JET213001 Counter top microwave
General Electric JET213002 Counter top microwave
General Electric JET214001 Counter top microwave
General Electric JET214002 Counter top microwave
General Electric JET220001 Counter top microwave
General Electric JET220002 Counter top microwave
General Electric JET220003 Counter top microwave
General Electric JET230001 Counter top microwave
General Electric JET230002 Counter top microwave
General Electric JET235001 Counter top microwave
General Electric JET235002 Counter top microwave
General Electric JET235003 Counter top microwave
General Electric JET320001 Counter top microwave
General Electric JET322001 Counter top microwave
General Electric JET322G01 Counter top microwave
General Electric JET322H01 Counter top microwave
General Electric JET340001 Counter top microwave
General Electric JET3400D1 Counter top microwave
General Electric JET342001 Counter top microwave
General Electric JET342G01 Counter top microwave
General Electric JET342H01 Counter top microwave
General Electric JET342HV01 Counter top microwave
General Electric JET343001 Counter top microwave
General Electric JET343G01 Counter top microwave
General Electric JET343G02 Counter top microwave
General Electric JET344J01 Counter top microwave
General Electric JET344JV01 Counter top microwave
General Electric JET424001 Counter top microwave
General Electric JET890A1 Counter top microwave
Jenn-Air JEW8527AAB Walloven - Std Ele
Jenn-Air JEW8527AAW Walloven - Std Ele
Jenn-Air JEW8530AAB Walloven - Std Ele
Jenn-Air JEW8530AAW Walloven - Std Ele
Jenn-Air JEW8530ACB Walloven - Std Ele
Jenn-Air JEW8530ACW Walloven - Std Ele
Jenn-Air JEW8627AAB Walloven - Std Ele
Jenn-Air JEW8627AAW Walloven - Std Ele
Jenn-Air JEW8630AAB Walloven - Std Ele
Jenn-Air JEW8630AAW Walloven - Std Ele
Jenn-Air JEW9527AAB Walloven - Std Ele
Jenn-Air JEW9527AAS Walloven - Std Ele
Jenn-Air JEW9527AAW Walloven - Std Ele
Jenn-Air JEW9530AAB Walloven - Std Ele
Jenn-Air JEW9530AAS Walloven - Std Ele
Jenn-Air JEW9530AAW Walloven - Std Ele
Jenn-Air JEW9530ACB Walloven - Std Ele
Jenn-Air JEW9530ACW Walloven - Std Ele
Jenn-Air JEW9627AAB Walloven - Std Ele
Jenn-Air JEW9627AAS Walloven - Std Ele
Jenn-Air JEW9627AAW Walloven - Std Ele
Jenn-Air JEW9630AAB Walloven - Std Ele
Jenn-Air JEW9630AAS Walloven - Std Ele
Jenn-Air JEW9630AAW Walloven - Std Ele
Jenn-Air JEW9630ACB Walloven - Std Ele
Jenn-Air JEW9630ACW Walloven - Std Ele
Jenn-Air JFC2070KRB Ref - Bottom Mounts
Jenn-Air JFC2070KRS Ref - Bottom Mounts
Jenn-Air JFC2070KRW Ref - Bottom Mounts
  #2 (permalink)
Old 11-07-2007, 05:59 AM
Junior Member
glenn.martz is on a distinguished road
Default jenn air clock
Look at the control ribbon coming out of the clock with a magnifier. Are there any creases? Try gently flexing the ribbon while it is installed to see if anything changes. I squished mine when I installed the new clock and caused several breaks in the printed circuits on the ribbon. You asked for any clues. Here is one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
E1 Code JSiemens Dryer Repair 8 02-04-2012 10:21 AM
ER code dkiper2928 Dishwasher Repair 1 10-28-2009 01:29 AM
F70 Code johnnydanger Washer Repair 6 10-20-2009 05:41 PM
Washer does everthing except spin. It does drain bbr6910 Washer Repair 2 09-02-2008 01:48 PM
Whirlpool Refrigerator Freezing Everthing in Fresh Food Section kathsv Refrigerator & Freezer Repair 0 08-13-2008 07:46 AM
