im having problems with my oven . first the bottom element went out then a few weeks later the bottom went out. should i replace both elements or should i replace the circuit board? does any one know?
hi gene.thanks for answering. o.k i pulled it out and checked it. they both have continuity.
Sounds like the problem is a bad Electronic Oven Control. It has to be replaced together with the overlay. - The EOC Part number: AP3775658
