Igniter gets red hot in 15 sec, takes 15min for gas to turn on & ignite. small flames(3/8") takes an hour to get to 350 degrees.It seems gas pressure is lacking only for the over, the broiler is fine. Do I need a new regulator? If so, are there simple instructions or maybe further tests? Thanks Jack
