Discuss
Whirlpool Double Oven Error Codes
 in
Serial #XL3506189, oven displays error code E6F2. After awhile oven will beep and I can set the clock and the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Oven Error Codes
  #1 (permalink)
Old 01-14-2009, 11:31 AM
alaucks alaucks is offline
Junior Member
alaucks is on a distinguished road
Default Whirlpool Double Oven Error Codes
Model Number: RBD306PDB12   Brand: Whirlpool   Age: 5 - 10 years
Serial #XL3506189, oven displays error code E6F2. After awhile oven will beep and I can set the clock and the oven will work for a little while then the error code comes up again. Sometimes oven works for days and sometimes is off for days. After contacting Whirlpool directly they told me I needed a new touch pad, P/N 8300437. Before we replaced the part a local service tech told us to pull the oven out to make sure there wasn't a loose neutral. Now since we pulled the oven out, the oven does nothing, it doesn't even display the error code anymore. We received the new touch pad and installed and the oven still doesn't work. We were now told that we need to replace the motherboard or micro computer which I'm guessing is the clock or controlboard P/N 8302967. Before ordering it I wanted to get a second opinion.
Thanks,
Andrea
Related Models
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
Amana RBK24AA Range - S/i Std Gas
Amana RBK24AA0 Range - S/i Std Gas
Amana RBK24AA093M Range - S/i Std Gas
Amana RBK24AA5 Range - S/i Std Gas
Amana RBK24AAL Range - S/c S/i Ddraft Gas
Amana RBK24AAW Range - S/c S/i Ddraft Gas
Amana RBK26AA Range - S/i Std Gas
Amana RBK26AA0 Range - S/i Std Gas
Amana RBK26AA093M Range - S/i Std Gas
Amana RBK26AA5 Range - S/i Std Gas
Amana RBK26AAL Range - S/c S/i Ddraft Gas
Amana RBK26AAW Range - S/c S/i Ddraft Gas
Amana RBK26CBL Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 01-14-2009, 04:53 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
I would check the terminal block, where the cord attaches to the back of the unit first, that sounds like a short.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 01-15-2009, 10:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Just to add my 2 cents...
Check the power outlet too or just try a different one.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire double oven twin error codes F23 top and bottom mitchfix1 Oven Repair (including Ranges and Cooktops) 3 12-01-2008 09:40 AM
Error Codes Whirlpool Oven brummel Oven Repair (including Ranges and Cooktops) 0 08-25-2008 01:27 PM
Whirlpool Double Oven RBD276PDB12 Error Codes fishnugget Oven Repair (including Ranges and Cooktops) 5 07-25-2008 03:56 PM
Whirlpool Gold Error Codes YPKenny412 Oven Repair (including Ranges and Cooktops) 0 06-30-2008 03:04 PM
error codes on whirlpool duet sport Thad Steele Washer Repair 1 11-02-2007 03:12 PM
