Hello: I'm sure you have had to answer this question numerous times in the past, but as a novice with no experience regarding cook top repairs, can anyone please advise as to the complexity of having to change only the glass top on a Jenn-Air Glass Cook Top Model Number JED8430ADQ. Specifically, what is involved? Is there a simple way to get this done or do I have to pull out the entire unit from its mooring in order to be able to simply replace the glass top? If given the opportunity, I can follow proper step by step instructions in order to get this done.
Thanking you in advance for any information you can provide regarding this matter.
Sincerely...Fireball.
