Discuss
Oven will not heat over 220 degrees
 in
The oven will only heat up to about 220 degrees and it takes a very long time to heat up
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not heat over 220 degrees
  #1 (permalink)
Old 01-12-2009, 05:57 AM
Junior Member
sandymb58 is on a distinguished road
Default Oven will not heat over 220 degrees
Brand: Amana   Age: 1 - 5 years
The oven will only heat up to about 220 degrees and it takes a very long time to heat up that high.
Everything else seems to work ok
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven doesn't heat higher than 375 degrees aml14103 Oven Repair (including Ranges and Cooktops) 6 03-25-2015 06:09 PM
Oven won't heat past 350 degrees tlpyle Oven Repair (including Ranges and Cooktops) 0 01-21-2010 02:56 PM
Oven won't heat above 425 degrees eurohopper Oven Repair (including Ranges and Cooktops) 0 01-09-2010 11:11 AM
Oven won't heat past 350 degrees tlpyle Oven Repair (including Ranges and Cooktops) 1 11-18-2008 12:41 PM
oven won't heat above 135 degrees John T. Oven Repair (including Ranges and Cooktops) 1 06-30-2008 09:10 AM
