Discuss
Thermador Controller Removal ?
 in
I am trying to remove (to repair) the Oven Timer Controller from the front of the stove. Must I remove
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Controller Removal ?
  #1 (permalink)
Old 04-08-2011, 11:56 AM
Junior Member
maxxgilbert is on a distinguished road
Default Thermador Controller Removal ?
Model Number: RDDS30VQB   Brand: Thermador   Age: More than 10 years
I am trying to remove (to repair) the Oven Timer Controller from the front of the stove. Must I remove the top of the stove to complete the task or can I slightly force up the stove top to remove the Controller ?
Thanks, Maxx
Related Models
Thermador RDDS30VQB PRIOR TO S/N 9707
Thermador RDDS30VQB S/N 9707 & UP
Thermador RDDS30VRS PRIOR TO S/N 9707
Thermador RDDS30VRS S/N 9707 & UP
Roper RDE22302 ELECTRIC RANGES AND OVENS
Whirlpool RDE32302
Thermador RDF30 30" DUAL-FUEL RANGE
Thermador RDF30QB PRIOR TO S/N 9708
Thermador RDF30QB S/N 9708 & UP
Thermador RDF30QW PRIOR TO S/N 9708
Thermador RDF30QW S/N 9708 & UP
Thermador RDF30RS PRIOR TO S/N 9707
Thermador RDF30RS S/N 9707 & UP
Thermador RDFS30
Thermador RDFS30 PRIOR TO S/N 9708
Thermador RDFS30 S/N 9708 & UP
Jenn-Air RDK100W MISC / ACCESSORY
Jenn-Air RDK226W MISC / ACCESSORY
Jenn-Air RDK246W MISC / ACCESSORY
Roper RDP34502 ELECTRIC RANGE AND OVEN
Whirlpool RDP34582
Amana RDS-648-UK RANGE- S/C S/I DDRAFT GAS
Thermador RDSS30 S/N 9707 & UP
General Electric RE101101 Electric range
General Electric RE101102 Electric range
General Electric RE101103 Electric range
General Electric RE102101 Electric range
General Electric RE102102 Electric range
General Electric RE102103 Electric range
Whirlpool RE123 Air-conditioner/heat pump
Whirlpool RE123A1 Air-conditioner/heat pump
Whirlpool RE123A2 AIR CONDITIONERS
Whirlpool RE123F0 AIR CONDITIONER
Whirlpool RE123G0 AIR CONDITIONER
Amana RE14010C2D ROOM AIR CONDITIONER
Amana RE14010C2D REV ROOM AIR CONDITIONER
Amana RE14010C2DR ROOM AIR CONDITIONER
Amana RE14010C2DR REV ROOM AIR CONDITIONER
General Electric RE140901 Electric range
General Electric RE1409G01 Electric range
General Electric RE1409G02 Electric range
General Electric RE141001 Electric range
General Electric RE142001 Electric range
General Electric RE144001 Electric range
General Electric RE1440G01 Electric range
General Electric RE1440G02 Electric range
General Electric RE1440H01 Electric range
General Electric RE1440H02 Electric range
General Electric RE145001 Electric range
General Electric RE1450G01 Electric range
General Electric RE1450G02 Electric range
General Electric RE1450H01 Electric range
General Electric RE1450H02 Electric range
Amana RE18010C2D ROOM AIR CONDITIONER
Amana RE18010C2D REV ROOM AIR CONDITIONER
Amana RE18010C2DR ROOM AIR CONDITIONER
Amana RE18010C2DR REV ROOM AIR CONDITIONER
Amana RE18090C2D ROOM AIR CONDITIONER
Amana RE18090C2D REV ROOM AIR CONDITIONER
Amana RE18090C2DR ROOM AIR CONDITIONER
Amana RE18090C2DR REV ROOM AIR CONDITIONER
Whirlpool RE183 Air-conditioner/heat pump
Whirlpool RE183A AIR CONDITIONER
Whirlpool RE183A1 AIR CONDITIONER
Whirlpool RE183A2 AIR CONDITIONER
Whirlpool RE183A3 AIR CONDITIONER
Whirlpool RE183G0 AIR CONDITIONER
Whirlpool RE243K0 ROOM AIR CONDITIONER
Whirlpool RE253E AIR CONDITIONER
Whirlpool RE253F0 AIR CONDITIONER
Whirlpool RE253G1 AIR CONDITIONER
Frigidaire RE32BNL1 Frg(v2) / Electric Range
Frigidaire RE32BNL2 Frg(v2) / Electric Range
Frigidaire RE32BNM1 Frg(v3) / Electric Range
Frigidaire RE32BNW1 Frg(v1) / Electric Range
Frigidaire RE32BNW2 Frg(v1) / Electric Range
Frigidaire RE34BAA3 Frg(v4) / Electric Range
Frigidaire RE34BAA4 Frg(v9) / Electric Range
Frigidaire RE34BAA5 Frg(v3) / Electric Range
Frigidaire RE34BAF3 Frg(v3) / Electric Range
Frigidaire RE34BAF4 Frg(v8) / Electric Range
Frigidaire RE34BAF5 Frg(v2) / Electric Range
Frigidaire RE34BAH2 Frg(v1) / Free Standing Electric Range
Frigidaire RE34BAH3 Frg(v5) / Electric Range
Frigidaire RE34BAH4 Frg(v10) / Electric Range
Frigidaire RE34BAH5 Frg(v4) / Electric Range
Frigidaire RE34BAL2 Frg(v2) / Free Standing Electric Range
Frigidaire RE34BAL3 Frg(v2) / Electric Range
Frigidaire RE34BAL4 Frg(v7) / Electric Range
Frigidaire RE34BAL5 Frg(v5) / Electric Range
Frigidaire RE34BAW2 Frg(v3) / Free Standing Electric Range
Frigidaire RE34BAW3 Frg(v1) / Electric Range
Frigidaire RE34BAW4 Frg(v6) / Electric Range
Frigidaire RE34BAW5 Frg(v1) / Electric Range
Frigidaire RE36BNL2 Frg(v2) / Electric Range
Frigidaire RE36BNL3 Frg(v2) / Electric Range
  #2 (permalink)
Old 04-12-2011, 09:23 AM
Junior Member
Default Model Number is actually: RDDS30VQB
Maxx's Question
Model Number: RDDS30VNQ I am trying to remove the 'Stove/Oven Timer' from the front of the unit. The question is...must I remove the top of the stove to successfully remove the part (Part #486752) ? Maxx
The model number is actually RDDS30VQB
Thanks , Maxx
  #3 (permalink)
Old 12-11-2011, 12:51 PM
Junior Member
whalerpaul is on a distinguished road
Default
did you determine the answer here? ... do you have to remove the tip drip pans to get to the timer, or does that come off the front with only disassembly for the front panel?
  #4 (permalink)
Old 03-10-2013, 06:27 PM
Junior Member
twolfe is on a distinguished road
Default
I have a slightly different unit (model number RDF30WQ) but has the same Stove/Oven Timer (486752). You do not need to remove the top to get to the this on mine. Two screws on each side (facing up) will release the face plate frame. The glass face plate then comes off after knobs are pulled out. A metal sub-plate that the unit is screwed to then comes out (8 screws on mine). At that point, you can removed the unit from the sub-plate.
Perhaps you can help me... My Stove/Oven Timer was removed by someone (not me) that did not tag the wires that plug into the unit. There are 9 plus a multi-wire plug. The 9 are labeled E1-E9 on the unit. Can you tell me which color wires plug into which plug on your unit? I have not been able to find this info so far.
  #5 (permalink)
Old 03-11-2013, 10:07 AM
Junior Member
Default
thanks for the information, I expect it will be useful to others on the site. I no longer have access to that Thermador stove. Have you called Thermador service/parts in CA or the east coast? I think they may help if you bought the replacement part from them.
good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador star burner removal drkeith Oven Repair (including Ranges and Cooktops) 7 04-08-2017 02:12 PM
Replacement of controller CDD Oven Repair (including Ranges and Cooktops) 0 02-11-2011 02:40 PM
Freezer Controller krquinn Refrigerator & Freezer Repair 0 01-22-2011 12:43 PM
Thermador Range top removal questions din209@bellsouth.net Oven Repair (including Ranges and Cooktops) 7 11-03-2009 11:47 PM
Thermador wall oven removal arnold12 Oven Repair (including Ranges and Cooktops) 0 07-05-2009 02:17 PM
