| » Broken Support, hinge counter for oven door |
Model Number: PGR364GL/GD Brand: Thermador Age: 5 - 10 years
I broke one of the rivets for the right hinge counter on the oven while reinstalling the floor pan of for the oven.
I need to replace this part but I do no know where to start? I see the 2 mounting screw on the outside of the oven body for the part but am lost after that. Any help would be great. Related Models |
I'm afraid I did not get it clear. Can you refer to a drawing reference number(s) from the break down diagrams for the Thermador range Model PGR364GLZS?
__________________
Professional appliance repair in Orange County, California. |
the bottom support pin broke so the door will not hang on the oven I ordered this piece to fix it. Part Details - BOSCH Support, hinge counter, part number: AP2832441 I don`t know what to take off to install it? I hope its the right part? I am an amateur at this. |
It is part number 22 on this diagram
Model PRG364GL |
If there is no more letters after "L" in the model number then looks like this is the right part number. Per the diagram you have top remove the side panel to access the part.
__________________
Gene,
1.Should I remove the side panel from the inside of the oven? 2.Where do you access the side oven liner screws to remove it? Model PRG364GL Thanks for the help so far! |
You can find the instructions attached to this post.
__________________
| Display Modes | |
| LG French Door / Bottom Freezer Door Hinge Cam Broken - Looking for install procedure | ServicePlus | Refrigerator & Freezer Repair | 13 | 08-21-2009 09:26 PM |
| oven door hinge broke,so did hinge post for top | Melodygmd | Oven Repair (including Ranges and Cooktops) | 1 | 12-30-2008 05:32 PM |
| Hinge on metal door is broken | BAKERWG | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2008 07:49 AM |
| Lower arm spray support (hub) broken | gabhroo | Dishwasher Repair | 5 | 12-10-2007 01:36 PM |
| Broken door hinge | dbrock | Dishwasher Repair | 1 | 09-20-2007 03:54 AM |
