I have a an odd height range that I am determined to fix than replace. The stove top burneres work fine. The oven is the problem, not working, the elements are fine, I have bypassed the timer and looking at the Oven/Selector control as the problem. Selector Part # 1312537. No matter if its on oven or broil I get 120 volts at all 4 element connections simotainusly? Any Suggestions. johncostig attached the following image(s):
