Discuss
oven does not heat to temp
 in
I just replaced a 43-year old Frigidaire double wall oven after it repeatedly tripped the breaker. After resetting the breaker,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven does not heat to temp
  #1 (permalink)
Old 01-11-2009, 07:49 AM
Junior Member
bptt is on a distinguished road
Default oven does not heat to temp
Brand: Kenmore   Age: Less than 1 year
I just replaced a 43-year old Frigidaire double wall oven after it repeatedly tripped the breaker. After resetting the breaker, power continued to the oven, but lower oven did not heat at all, and upper oven did not heat to desired temperature.
I assumed the problem was the oven itself, and ordered a new Kenmore that was installed two days ago. During installation, the installer noted it appeared that there had been a short in the wiring connections inside the junction box behind the oven. He clipped the old wires and make new connections.
After installation, and during the first operation of both ovens, the breaker tripped while both upper and lower ovens while both were set to 350 at the same time. This did not happen right away but about 10 minutes after starting while both were heating. The installer thought the dedicated circuit breaker for the oven needed to be replaced, but did not have one with him. He said we could operate one oven at a time prior to replacing the breaker. However, when I tried to run just the upper oven, it did not appear to reach 350 default temperature.
Does this sound like a problem with the dedicated circuit breaker for the oven? I bought a replacement breaker but have not installed it yet.
Ads By Google
  #2 (permalink)
Old 01-11-2009, 07:58 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
I would replace the breaker. Tom ********************************************
  #3 (permalink)
Old 01-14-2009, 03:17 PM
Junior Member
Thumbs up oven does not heat to temp
Replacing the circuit breaker seems to have solved the problem....thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't re-heat to keep temp up. lynnhex Oven Repair (including Ranges and Cooktops) 4 02-29-2012 04:27 PM
Oven Does Not Heat To Correct Temp lucille789 Oven Repair (including Ranges and Cooktops) 11 10-30-2008 01:27 PM
oven does not heat to set temp Dave G Oven Repair (including Ranges and Cooktops) 0 05-24-2008 08:43 AM
Oven won't heat to temp docjolly Oven Repair (including Ranges and Cooktops) 0 09-03-2007 08:03 PM
Oven wont heat to temp rickm1959 Oven Repair (including Ranges and Cooktops) 1 07-24-2007 03:52 PM
