Originally Posted by: ovenparts I have a Maytag oven model #SVD48600P and the door does not completely shut. Is there something I can adjust or what parts will I need to replace? Thanks
Ovenparts, That is not a "common" problem on this style range (Jenn Air) at this stage of usage. the door seal has usually taken a "set" and the door may be slightly open or at an angle near the top. First thing you want to look at is the oven cavity front flange, make sure the area around the hinge openings are not bowed out at the tops of the opening. Make sure the inner door liner is not bowed or bent, with a straight edge. Check the door seal, along the bottom to see if it has started to deteriorate. If all these check OK, you'll need to replace the door hinges, Part number: AP4089724
