Discuss
Ruth Madden
 in
I set my oven to clean. The timer wasn't working so it didn't turn itself off. When I tried to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ruth Madden
  #1 (permalink)
Old 01-10-2009, 12:36 PM
Junior Member
Ruth Madden is on a distinguished road
Angry Ruth Madden
Model Number: 30-2662-00/11304-86410   Brand: Tappan   Age: More than 10 years
When I tried to unlock it wouldn't open. The oven is turned off, but I can't get the door open even though the lock is to the left. Can this problem be solved?
Ads By Google
Related Models
Frigidaire 30-2757-00-03 Tap(v1) / Gas Range
Frigidaire 30-2757-00-04 Tap(v4) / Gas Range
Frigidaire 30-2757-00-05 Tap(v1) / Gas Range
Frigidaire 30-2757-00-06 Tap(v4) / Gas Range
Frigidaire 30-2757-23-03 Tap(v2) / Gas Range
Frigidaire 30-2757-23-04 Tap(v5) / Gas Range
Frigidaire 30-2757-23-05 Tap(v2) / Gas Range
Frigidaire 30-2757-23-06 Tap(v5) / Gas Range
Frigidaire 30-2757-66-03 Tap(v3) / Gas Range
Frigidaire 30-2757-66-04 Tap(v6) / Gas Range
Frigidaire 30-2757-66-05 Tap(v3) / Gas Range
Frigidaire 30-2757-66-06 Tap(v6) / Gas Range
Frigidaire 30-2758-00-01 Tap(v1) / Gas Range
Frigidaire 30-2758-00-02 Tap(v7) / Gas Range
Frigidaire 30-2758-00-03 Tap(v1) / Gas Range
Frigidaire 30-2758-00-04 Tap(v4) / Gas Range
Frigidaire 30-2758-23-01 Tap(v2) / Gas Range
Frigidaire 30-2758-23-02 Tap(v8) / Gas Range
Frigidaire 30-2758-23-03 Tap(v2) / Gas Range
Frigidaire 30-2758-23-04 Tap(v5) / Gas Range
Frigidaire 30-2758-66-01 Tap(v3) / Gas Range
Frigidaire 30-2758-66-02 Tap(v9) / Gas Range
Frigidaire 30-2758-66-03 Tap(v3) / Gas Range
Frigidaire 30-2758-66-04 Tap(v6) / Gas Range
Frigidaire 30-2759-00-01 Tap(v1) / Gas Range
Frigidaire 30-2759-00-02 Tap(v3) / Gas Range
Frigidaire 30-2759-00-03 Tap(v5) / Gas Range
Frigidaire 30-2759-00-04 Tap(v1) / Gas Range
Frigidaire 30-2759-00-05 Tap(v1) / Gas Range
Frigidaire 30-2759-00-06 Tap(v1) / Gas Range
Frigidaire 30-2759-00-07 Tap(v1) / Gas Range
Frigidaire 30-2759-00-08 Tap(v3) / Gas Range
Frigidaire 30-2759-00-09 Tap(v1) / Gas Range
Frigidaire 30-2759-00-10 Tap(v1) / Gas Range
Frigidaire 30-2759-23-01 Tap(v2) / Gas Range
Frigidaire 30-2759-23-02 Tap(v4) / Gas Range
Frigidaire 30-2759-23-03 Tap(v6) / Gas Range
Frigidaire 30-2759-23-04 Tap(v2) / Gas Range
Frigidaire 30-2759-23-05 Tap(v2) / Gas Range
Frigidaire 30-2759-23-06 Tap(v2) / Gas Range
Frigidaire 30-2759-23-07 Tap(v2) / Gas Range
Frigidaire 30-2759-23-08 Tap(v4) / Gas Range
Frigidaire 30-2759-23-09 Tap(v2) / Gas Range
Frigidaire 30-2759-23-10 Tap(v2) / Gas Range
Frigidaire 30-2761-00-01 Tap(v1) / Gas Range
Frigidaire 30-2761-00-02 Tap(v1) / Gas Range
Frigidaire 30-2761-00-03 Tap(v3) / Gas Range
Frigidaire 30-2761-00-05 Tap(v1) / Gas Range
Frigidaire 30-2761-00-06 Tap(v3) / Gas Range
Frigidaire 30-2761-00-07 Tap(v3) / Gas Range
Frigidaire 30-2761-23-01 Tap(v2) / Gas Range
Frigidaire 30-2761-23-02 Tap(v2) / Gas Range
Frigidaire 30-2761-23-03 Tap(v4) / Gas Range
Frigidaire 30-2761-23-05 Tap(v2) / Gas Range
Frigidaire 30-2761-23-06 Tap(v4) / Gas Range
Frigidaire 30-2761-23-07 Tap(v4) / Gas Range
Frigidaire 30-2769-00-01 Tap(v1) / Gas Range
Frigidaire 30-2769-00-02 Tap(v3) / Gas Range
Frigidaire 30-2769-23-01 Tap(v2) / Gas Range
Frigidaire 30-2769-23-02 Tap(v4) / Gas Range
Frigidaire 30-3026-00-01 Tap(v1)
Frigidaire 30-3026-00-02 Tap(v2)
Frigidaire 30-3026-00-03 Tap(v3)
Frigidaire 30-3026-00-04 Tap(v4)
Frigidaire 30-3026-23-01 Tap(v5)
Frigidaire 30-3026-23-02 Tap(v6)
Frigidaire 30-3026-23-03 Tap(v7)
Frigidaire 30-3026-23-04 Tap(v8)
Frigidaire 30-3036-00-01 Tap(v9)
Frigidaire 30-3036-00-02 Tap(v10)
Frigidaire 30-3036-00-03 Tap(v11)
Frigidaire 30-3036-00-04 Tap(v12)
Frigidaire 30-3036-23-01 Tap(v13)
Frigidaire 30-3036-23-02 Tap(v14)
Frigidaire 30-3036-23-03 Tap(v15)
Frigidaire 30-3036-23-04 Tap(v16)
Frigidaire 30-3053-00-01 Tap(v1) / Gas Range
Frigidaire 30-3053-00-02 Tap(v1) / Gas Range
Frigidaire 30-3053-00-03 Tap(v1) / Gas Range
Frigidaire 30-3053-00-04 Tap(v1) / Gas Range
Frigidaire 30-3053-23-01 Tap(v2) / Gas Range
Frigidaire 30-3053-23-02 Tap(v2) / Gas Range
Frigidaire 30-3053-23-03 Tap(v2) / Gas Range
Frigidaire 30-3053-23-04 Tap(v2) / Gas Range
Frigidaire 30-3147-00-01 Tap(v1) / Gas Range
Frigidaire 30-3147-00-02 Tap(v4) / Gas Range
Frigidaire 30-3147-00-03 Tap(v7) / Gas Range
Frigidaire 30-3147-23-01 Tap(v2) / Gas Range
Frigidaire 30-3147-23-02 Tap(v5) / Gas Range
Frigidaire 30-3147-23-03 Tap(v8) / Gas Range
Frigidaire 30-3147-66-01 Tap(v3) / Gas Range
Frigidaire 30-3147-66-02 Tap(v6) / Gas Range
Frigidaire 30-3147-66-03 Tap(v9) / Gas Range
Frigidaire 30-3148-00-01 Tap(v1) / Gas Range
Frigidaire 30-3148-00-02 Tap(v4) / Gas Range
Frigidaire 30-3148-00-03 Tap(v7) / Gas Range
Frigidaire 30-3148-23-01 Tap(v2) / Gas Range
Frigidaire 30-3148-23-02 Tap(v5) / Gas Range
Frigidaire 30-3148-23-03 Tap(v8) / Gas Range
Frigidaire 30-3148-66-01 Tap(v3) / Gas Range
Frigidaire 30-3148-66-02 Tap(v6) / Gas Range
Frigidaire 30-3148-66-03 Tap(v9) / Gas Range
Frigidaire 30-3152-00-01 Tap(v1) / Gas Range
Frigidaire 30-3152-00-02 Tap(v1) / Gas Range
Frigidaire 30-3152-00-03 Tap(v1) / Gas Range
Frigidaire 30-3152-00-04 Tap(v2) / Gas Range
Frigidaire 30-3152-23-01 Tap(v2) / Gas Range
Frigidaire 30-3152-23-02 Tap(v2) / Gas Range
Frigidaire 30-3152-23-03 Tap(v3) / Gas Range
Frigidaire 30-3152-23-04 Tap(v4) / Gas Range
Frigidaire 30-3226-00-01 Tap(v17)
Frigidaire 30-3226-00-02 Tap(v18)
Frigidaire 30-3226-00-03 Tap(v19)
Frigidaire 30-3226-00-04 Tap(v20)
Frigidaire 30-3226-23-01 Tap(v1) / Gas Range
Frigidaire 30-3226-23-02 Tap(v2) / Gas Range
Frigidaire 30-3226-23-03 Tap(v3) / Gas Range
Frigidaire 30-3226-23-04 Tap(v4) / Gas Range
Frigidaire 30-3236-00-01 Tap(v5) / Gas Range
Frigidaire 30-3236-00-02 Tap(v6) / Gas Range
  #2 (permalink)
Old 01-10-2009, 12:40 PM
Junior Member
Default
My oven door will not open after cleaning. The clock is not working and I had to manually turn the settings. This did not work. The oven is off. The lock latch is in the open position, but it still won't open. Any idea what I should do?
  #3 (permalink)
Old 01-10-2009, 08:32 PM
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
you may have to acess the latching mechanism from back of stove
__________________
  #4 (permalink)
Old 01-10-2009, 10:54 PM
Junior Member
getcooking is on a distinguished road
Default need Model #
getting in to a locked oven can be a lot of fun to help i would need to know what kind of door lock motor you have , i could look that up with your model #
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
