You have been a member since:: 4/5/2011(UTC) Posts: 1
burner range works broiler works I replaced the bottom ignitor element and it worked for two days, but now the oven is not heating up again. I have checked the metal tubing directing the gas from the valve and that is clear. My initial instinct was the gas valve, but if all the other parts are heating up then that should not be the issue. Any suggestions?
