I have discovered a straight line crack going from the burner outwards about 6 in. and 2in with no crack and then a 2in crack in the other direction. No one at Whirlpool was able to advise if I could use the other 3 burners or the oven until a tech comes out to see if its heat related. I am worried that if the range is getting too hot it could get worse or something else is there anyway to test myself or is there a common way a heat related crack runs to try to determine?
We have only owned just over 90 days and the hassel and no answers is really fustrating. Thanks for any advice.:mad:
