This is a glass top range. the front right burner goes on and stays at one temperture . the dial does not control this. I am thinking either bad switch or element. Can someone help me please Email : newmanpi1@yahoo.com
The problem most likely is a bad infinite switch for this burner. According to the diagram, the front right burner is dual, so for this burner the infinite switch Part number: AP2124692
Originally Posted by: Gene The problem most likely is a bad infinite switch for this burner. According to the diagram, the front right burner is dual, so for this burner the infinite switch Part number: AP2124692
Thank you, I will order the part. now i need to figure out how to remove the top to replace this part. any ideas?
Remove the rear cover for the control panel.
Originally Posted by: Gene Remove the rear cover for the control panel.
Gene. Thanks again. I ordered the switch.
