Just this weekend, my gas range has begun tripping the circuit breaker. I can set the temp, and it will begin to warm up as normal. At some point after it is nearly up to temperature, it will pop and trip the circuit breaker. The most recent occurrence, it tripped twice when set to 400deg. When I set it to 350deg, it didn't have any problem. All the other functions - timer, clock, etc seem to be working normal. It was installed 6mos ago and has just started this behaviour. It is on a circuit with multiple outlets, but it is the only thing in use when it trips.
